Topic: Fireface UCX II - Matching gain levels between lines 1&2 and 3-8
Hi everyone!
I just got my new UCX II and I am testing it.
So far I am impressed by the sound quality, but there is something I cannot really understand.
I am trying to use it as a AD converter, for an external 8ch preamp (DAV BG8).
The output of this preamp is +4dBu.
Therefore, up to my understanding, I have set the input levels of the lines 3-8 to +13dBu and I get a good sound level.
The Line inputs 1+2 are sounding much softer, and the manual says that there is a -6dB attenuation.
If I add the 6dB to the 1&2 channels, I still get a softer sound.
When I tune the levels by ears, I found out that the ideal spot for having a consistent gain level across all the 8 channels (with of course the same gain and same microphones from the DAV!) is to add 11dB to the channels 1 and 2.
I basically "tuned it" connecting one channel to line 1 and the other channel to line 5.
Microphones are the same, both capsules are very close to each other and the gain from the DAV is the same.
Any thought about this? Where this 11dB number comes from?
Am I missing something?
Looking forward to your help!
Cheers,
Marco
