Topic: audio ticks with RME 9636 / Windows XP / independent from latency
I worked with my digi9636 for 5 years without any problems under WinXP (SP1,2, and 3) even with a huge amount of audio codecs. I rebuild my System, now I have WinXP, the latest driver for the 9636 and no matter which audio file I play I have ticks. Of course the on board soundcard is deactivated in the Bios (always was). The problem appeared on a clean system so its no matter of an audio codec conflict. Latency low or high makes no difference. I can say for sure its a problem with the digi9636 because for a test I activated the on board souncard which works fine. It is also not a problem with Cubase because the ticks are there with every tool playing audio files (mp3, wav, aif, etc etc). I am using it together with a Creamware ultra, of course I checked other inputs, ouputs here. But the Creamware is a simple device, it doesnt come with a driver.
I hope someone can help me (use a different slot, reinstall card, use other latency is not a solution!)
Thanx, Ingo
Re: audio ticks with RME 9636 / Windows XP / independent from latency
Sounds like a sync problem between the card and the converter, how is clocking configured?
Did you remember to do the "background services" tweak in XP?
http://www.soundonsound.com/sos/sep06/a … n_0906.htm
Check for general problems using a tool in the link below.
http://www.rme-audio.de/forum/viewtopic.php?id=1704
Hi Jeff,
thanx a lot for your fast help.
Crazy, I changed Auto Clock from Master to Auto Sync and the ticks are gone. How is it possible I didn´t have problems on my old system with Master? HeadScratch
cheers, ingo
Well, something must have changed in the converter settings. One device must be master (internal clock), the other must be slave (external clock). If both are set to internal, or both are set to external, then you don't have sync between the two devices.
