Topic: hdspe madi broken with Fedora 14 only, works with other distros
This is my first post so here goes.  I have installed a vanilla fedora 14 with all the necessary updates and alsa stuff to run under jack.  As soon as I insert my hdspe madi and boot, it boots fine up to the login screen.  As soon as I login, the system freezes completely shortly after.  I do have the latest bios update for the hdspe madi as well as my asus p5q-e motherboard.  Sometimes after login, i have a few seconds before freeze in which i ran lspci.  The madi card does show up where it needs to be.  In my frustration I have installed a version of archlinux and the card works perfectly with all the updated alsa utilities and running under jack.  Is this a fedora only issue that I should post with them?  Do you rme guys have any ideas?
thanks,
jason
Re: hdspe madi broken with Fedora 14 only, works with other distros
try running "echo "performance" > /sys/module/pcie_aspm/parameters/policy" as root before login please.
