Topic: Trouble when using 2nd DIGI9632/52
Windows 7 32 bit with latest drivers for DIGI. Both cards are seen by DAW (NUENDO 4). I only have the first card sending lightpipe to an Alesis HD24XR. The HD24XR locks to the ADAT via Optical without problems. However I am getting distortion at some points (its inconsistent as to where in the audio tracks). I made the cards Master for sync. I'm only using them for playback at this point. I have to admit there are many settings in the control panel that I am clueless as to their proper setting or use.
I removed the second card and so far everything is working 100% as I was not able to reproduce the problem. Upon re-installing card 2 I started to experience the same problem. So all points to some sort of loss of sync or compatibility.
I will try next to remove both cards and use only card 2 to see if maybe it is the card itself as opposed to a software problem.
If anyone has any ideas please let me know. Thanks.
Jim
2 (edited by vinark 2011-06-20 19:08:36)
Re: Trouble when using 2nd DIGI9632/52
both cards need to be synced too.
though i´m not sure this could cause the symptoms.
Missing sync, the cards run free and will eventually run out of sync...  A physical connection is required.
Daniel, that was the last thing I was going to try! Thanks for advise.
I'll do that next (I'm just exhausted from listening to the same 24 tracks over and over and over.....argh...).
So if I understand you correctly, if I connect 1 of the 3 ADAT Optical cables to the second card (16 tracks on 1st card and 8 tracks on 2nd) they should both work?
What I don't get is why if I am only using 1 card does it loose sync if 2nd card is not used? They are dependent on each other?
Anyway I will test tonight and report my findings.
Jim
You can use SPDIF, too...
ASIO driver uses/loads both cards...
Not doing good. I just tried the 2 cards with the 2nd card using 1 ADAT cable as sync. It didn't like it at all. Says it locks but it shows all 3 ports locked (only 1 connected) and the sync is at 96khz instead of 48khz!
I disabled all other PCI cards except for the 2 DIGI ones just in case.
The first card shows sync as MASTER. When I use the 2nd card what should the control panel settings be? Should 2nd card also be MASTER?
You advised using SPDIF to sync. I don't have any SPDIF gear. The HD24XR is ADAT. I also have an Alesis 8 channel interface. I have not tried syncing the second card to that. I'll try that next.
I really appreciate the help you are giving me.
Cheers
Jim
Second card must be Autosync, and I meant SPDIF from one card to the other...
I've now tried every combination I can think of. Having a 2nd card installed does not work.
Tried making the 2nd card "Autosync" and it seems to be OK but eventually the audio goes crazy. Sometimes I look at the control panel and 2nd card thinks its sync'd at 96khz!
Not sure what you mean by SPDIF? Do you mean I should run an ADAT cable from card 1 to card 2?
What about Word Clock out from card 1 to Word Clock in of card 2?
Right now I've given up and will probably end up selling one card (they both work perfectly on their own). I need 8 to 16 more ADAT outputs so I am wondering if a new PCI HDSP 9632 would work?
Oh well.
Jim
9 (edited by Bluzzi 2011-06-21 14:49:32)
Daniel, the DIGI cards have some pins on them. I have to look again but is it possible that these are used to connect one card to another for purpose of synchronizing?
I don't have a manual for these. I'll check now and see if there is one in the RME downloads section.
(OK I found the manual. The DB9 connector has SPDIF but I see that in the back there are 2 pins for CARD 1 Sync out and CD1. If I connect Sync from card 1 to CD1 of card 2 is that the idea? Or must it be via the SPDIF of the DB9?)
Thanks.
Cheers
Jim
Anyone have an answer for connecting 2 cards together?
I need to know which pins on card 1 should be connected to which pins on card 2.
See image below image for the various pins.
Jim
[img align=l]http://www.vibrolux.org/DIGI9636-52.jpg[/img]
If anything could work it woulde be sync out to cd in. Set the cd in card to autosync. This is in manual!
You could also simply use the RCA SPDIF connection, if it's not used otherwise.
