1 (edited by doodoo52 2011-08-05 12:51:15)
Topic: adi96 driver for window 7 64 bit
hi
were can i find and download a driver of adi96  for window 7 64 bit
Re: adi96 driver for window 7 64 bit
The ADI-96 does not require a driver. The remote control software apparently can not be installed, though, I tried various compatibility modes....
thank you but what do you mean by various compatibility modes...
Older software can be run in "compatibility modes", whereby W7 will act as if it were e.g. XP... But this did not help here, I could not run the setup file.
so there is no way to run it on w.7 , but all the ather fanctions of the adi96 will works on w.7 64 bit?
The ADI is a standalone converter. It does need to connect to a computer.
"The ADI is a standalone converter. It does need to connect to a computer".
yes i anderstend
1- but if i will record with the adi96 throw my ff400 rme it will work with w.7 64 bit?
2 -and can you tell me if the converters of the adi 69 will give me better sound then the converters of the rme ff 400?
1 - sure - why not...?
2 - only your ears can decide....
9 (edited by doodoo52 2011-08-05 15:35:31)
o k- but can you tell me what your ears  decide?
Sorry, I don't have an ADI-96...
thank you for helping me
have a good day.
david.
