Topic: Total mix and CC Midi codes
Hi all
I use to control Totalmix (last FF800 version) with a BCR2000 (with CC Midi codes).
I have switches to select an output and then mix inputs with the 24 BCR's pots that go through the selected output.
But the problem is, when i select another output, BCR's pots remains in the previous position, so when i touch one, it go back to last position (I don't know if I'm realy clear..)
So I was wondering if the totalmix could generate CC Midi codes to send to the BCR and tell the pots their "new position" ?
Thanks in advance,
Adrien G
