Topic: TotalMix FX feature upgrade request
- 1)   The maximum (Lo-Cut) x-over frequency is currently 500. Could this maximum be raised? (eg: 5000, or 9000, or 9999)
- 2)   It would also be great If it were possible to get a better view of the EQ graph.  (EG: double click the graph for a popup window of a larger, more detailed graph)
- 3)   I mentioned this one before, so a reply is not needed;    Hi-cut X-over
Thx RME, I would love to hear your thoughts on the request
- Justin
Re: TotalMix FX feature upgrade request
I am not sure that you are on the latest drivers, TM FX and manual. The third band of the EQ got an additional Hi-Pass function some time ago, also we removed the limitations in frequency range in all three bands. The Lo Cut is a Lo cut and will not be changed to (who needs that?) crazy values. A better (bigger) EQ display might indeed come some day.
