1 (edited by zapyz 2012-08-08 08:10:22)
Topic: OSX 10.8 + Fireface UCX : No MIDI
I migrated yesterday to my new MacBook Pro and I'm having a problem with MIDI.
The MIDI doesn't appear in TotalMix MIDI Settings :
http://data.imagup.com/12/1159073847.4152PNG
http://data.imagup.com/10/1159073917.4204PNG
Or any DAW :
http://data.imagup.com/11/1159074743.5646PNG
I didn't understand it directly, but this is probably the reason why ProTools or Reaktor are so slow on startup.
When I open the OS X "Audio and MIDI settings" (Sorry as it is here in french I don't know how it is called in english) it is loading for a very long time and, after a while, it displays a error message saying that it could not load because of a MIDI manager :
http://data.imagup.com/12/1159074412.5131PNG
"Audio and MIDI settings could not open the MIDI server, preventing you to consult or modify you MIDI configurations.
If you recently installed a MIDI manager, try to uninstall it and opening Audio and MIDI settings again. If Audio and MIDI settings doesn't work correctly after that, contact the manufacturer of the manager to get assistance."
I ran a new install of the latest drivers but it didn't change anything.
What should I do ?
Thanks for your help !
Re: OSX 10.8 + Fireface UCX : No MIDI
USB or FireWire? Latest drivers are from yesterday...
USB (I didn't get hold of a TB>FW adapter yet).
I downloaded the drivers yesterday : v1.75.
Can you explain 'migrated' in detail? This error is unknown so far, and IMHO would not happen on a new machine with a clean install of 10.8.
5 (edited by zapyz 2012-08-08 10:16:33)
I used OS X migration assistant including apps and installed the RME drivers just after that.
I can try to uninstall completely the driver.
Are these instructions still up-to-date: http://www.rme-audio.de/forum/viewtopic.php?id=9233 ?
6
http://www.rme-audio.de/forum/viewtopic … 611#p21611
That was the perfect solution, thanks a lot MC!
