Topic: Total Mix question
I'm trying to get used to Total mix.
I played music and I saw 3 level meters moving. one on the phone channel, Main out channel (Assigned to Analog out 3/4), and AN 1/2 on Hardware output.
I couldn't figure out why there's a signal on AN 1/2 on Hardware output.
As it described on a UFX manual, 29-4 Doubling the output signal, I think Totalmix automatically set up this way if I'm not wrong.
Since I don't need to double the output signal nor sending a cue to anywhere, How can I turn this off?  Thank you.
Re: Total Mix question
Please click this channel in submix mode (it gets brighter) and check the input and playback channel rows for open faders. If any fader is not all the way down, this channel sends a signal to AN1/2 output.
Or have a look in the matrix to see which channel sends a signal to this output.
best regards
Knut
Thank you. that helped!
