Topic: UCX Problems
Just opened the box and connected it with the firewire cable, installed from the disc supplied and all seemed to work fine except for a few levels on total mix which may be a ground problem from listening to the it on the phones.
I then updated the drivers and firmware and of course had to use USB and the power supply, and all seemed well. I removed the USB and power supply again after shutting down and rebooted. The unit lit up as before but the host light stayed red and of course it wasnt available on the PC.
Tried rebooting, checking the firewire cable hadn't worked loose, but no joy. I then plugged in the USB cable and it worked again, powered I imagine from the firewire as the power supply was not connected.
I would like to use this from firewire, any ideas what has happened? And can I get it back to the state it was before the firmware update if thats the problem? I'm on Windows 7.
