Topic: Gain for input channel 9/10 using ASIO drivers
Hi there,
Background:
I've connected an Earthworks M30 (sensitivity: 31mV/Pa) to a Fireface UFX on input channel 9. I interface with it using ASIO drivers. I need to get absolute data on sound pressure, so I need to setup UFX for the measurement program I use (ARTA).
Questions:
a) When I read the M30 signal using the ASIO driver, what gain has been applied to it - if any? The default value here is 1 (unaltered).
b) What is the maximum input voltage?
My measurement software needs both these values. Why it needs #a is pretty clear since it couldn't estimate pressure without it, but I'm not quite sure why it needs #b.
Thanks!
