Topic: aes
hi,
today i did connect my consumer cd player into the ufx, via digital optical. in adat 2 optical in. then in usb setting : aes input source = adat2.
the question is :
should i set the clock source to internal or aes or adat2.
you may say adat2, and then, right, the usb setting rate switch to the proper cd sr, 44,1.
but then if i play a protools 48, PT says : bad rate etc
ok
then i switch back the clock source to internal.
and then it's ok to both CD and PT.
BUT WHAT HAPPEN TO THE 44,1 CD RATE ?
it does not feel like it's pitched up. but is this wrong to hear 44,1 with a 48 clock rate ?
MACPRO/UFX via USB/ LATEST DRIVER+TMFX
ALL
