Topic: Asio Multimedia and Cubase SX
Hi!
I'm having problems setting up asio multimedia for cubase sx again, after it works perfect for 6 years with my RME 800
when i start the sync test for Fireface 800 Analog 1+2 MME Output in asio multimedia settings i get
Errorcode: FF8-5-000C
Device could not be opened
when i start the same test for Fireface 800 Analog 1+2 MME Input in asio multimedia settings the test starts but nothing happens
after that the window: your asio settings changed, would you like to test? I answer yes
In this actual configuration not all devices could be started with the selected options
(i hope i translated error message from german language correctly)
RME 800 Driver Version 2.95 & Hardware Revision 2.77
Windows XP SP3
Cubase SX3 Version 3.1.1 built on Oct 13 2005
any help would be appreciated
by(e)
hudriwudri
