Topic: ucx, samplitude and clicks
hello to everyone,
as in my old discussions i had problems with digital clicks so i thought that the best way would be a mac via bootcamp, considering i use samplitude with rme ucx.
But the problems are not finished:-O
Configuration:
macbook pro 13 2011 with bootcamp last version
fireface ucx with last drivers (both usb and firewire had the same problems)
samplitude 11 pro (with usb key license control)
i have audio clicks and buffer lost in samplitude, so i made some tests with latencymon.
In attachment what are the problems. Il seems to be the ACPI.sys driver, but it is so strange because from device manager it is DISABLE (ACPI COMPLIANT CONTROL.....)!!!
If somebody tell me the solution will make me very happy, because y i think also the mac go out from the window in few days.
I'm always more convinced that all the computers, also the mac, nowadays are computers for mobile and not for pro audio.
Perhaps pc built for audio, as ADK, go well, but i have not test them.
The problem is NOT the audio card, on mountain lion with digital performer is OK!
I will the tomorrow ucx with another sequencer on windows.
CONCLUSION
_________________________________________________________________________________________________________
Your system seems to have difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:05:51 (h:mm:ss) on all processors in the system.
SYSTEM INFORMATION
Computer name: ALESSANDRO-PC
OS version: Windows 7 Service Pack 1, 6.1, build: 7601 (x64)
CPU: GenuineIntel Intel(R) Core(TM) i5-2415M CPU @ 2.30GHz
Logical processors: 4
Processor groups: 1
RAM: 4006 MB total
CPU SPEED
Reported CPU speed: 2294,0 MHz
Measured CPU speed: 1728,0 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED KERNEL TIMER LATENCIES
Highest measured kernel timer latency (µs): 388,213482
MEASURED SMIs AND CPU STALLS
Highest measured SMI, IPI or CPU stall (µs) 25,434676
REPORTED DPCs
Highest DPC routine execution time (µs): 1495,637315
Driver with highest DPC routine execution time: ACPI.sys - ACPI Driver for NT, Microsoft Corporation
Highest reported total DPC routine time (%): 3,169778
Driver with highest DPC total execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in DPCs (%) 3,786829
DPC count (execution time <250 µs): 3922687
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 11
DPC count (execution time 1000-1999 µs): 2
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED ISRs
Highest ISR routine execution time (µs): 43,644725
Driver with highest ISR routine execution time: ataport.SYS - ATAPI Driver Extension, Microsoft Corporation
Highest reported total ISR routine time (%): 1,331808
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 1,480802
ISR count (execution time <250 µs): 2542577
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: none
Total number of hard pagefaults 213
Hard pagefault count of hardest hit process: 66
Highest hard pagefault resolution time (µs): 174504,111595
Total time spent in hard pagefaults (%): 0,173809
Number of processes hit: 0
PER CPU DATA
CPU 0 Interrupt cycle time (s): 78,220885
CPU 0 ISR highest execution time (µs): 43,644725
CPU 0 ISR total execution time (s): 20,794313
CPU 0 ISR count: 2542577
CPU 0 DPC highest execution time (µs): 1495,637315
CPU 0 DPC total execution time (s): 53,076133
CPU 0 DPC count: 3904487
CPU 1 Interrupt cycle time (s): 0,648767
CPU 1 ISR highest execution time (µs): 0,0
CPU 1 ISR total execution time (s): 0,0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 23,917175
CPU 1 DPC total execution time (s): 0,032277
CPU 1 DPC count: 5833
CPU 2 Interrupt cycle time (s): 1,091457
CPU 2 ISR highest execution time (µs): 0,0
CPU 2 ISR total execution time (s): 0,0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 112,244987
CPU 2 DPC total execution time (s): 0,064697
CPU 2 DPC count: 10984
CPU 3 Interrupt cycle time (s): 0,054368
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 45,032694
CPU 3 DPC total execution time (s): 0,003819
CPU 3 DPC count: 1396
