Topic: ff 400 low latency
Any value set below the default 256 samples settings at 44.1kHz produces pops and clicks. I'm running on a decently fast i7 DAW under Windows 7 x64 using sonar 8.5. 256 samples produces an acceptable 5..8ms latency however I'd hoped to get a bit lower. Has anyone else been able to achieve lower latency with the FF400?
And yes, I have installed the latest driver and firmware.
