Topic: Raydat driver question
Tomorrow I will be replacing my HDSP9652 with a new Raydat card in my Windows 7 system.  It appears they take the same driver.  Should I just remove the 9652 and plug the Raydat into the same slot without uninstalling the current driver, or should I uninstall the current driver and do a fresh driver install when I install the new Raydat card?
Thank You,
Lungboi
Re: Raydat driver question
Just replace the board, Windows will then search for drivers. If it doesn't find them use the installation hints from the manual.
Thank you!
