Topic: HDSPe Settings Quit Unexpectedly...
My setup is as follows: Multiface MK1, HDSPe PCIe card and Hac Pro 3,1 running 10.8.5
I realise that hacks are not supported by RME but I'm going out of my mind... I can't work out what is going on.
I have 10.8.5 installed and it recognises my HDSPe PCI card as an audio device (was surprised not to see it show up as a PCI device). The PCIe card is updated to latest firmware and I'm using the latest HDSPe driver (3.05).
The Multiface MK1 and the card seem to be happy with each other as there is no error light showing... so far so good.
However, when 'settings' start automatically after logon or after I quit it and restart the app, I get the "HDSPe Settings Quit Unexpectedly" every time.
I can't change the settings at all. When the mixer is started up sometimes it shows 8 analogue ins/outs and sometimes just 4 in/outs. Also, the mixer outputs are sometimes maxed out.
I've attached a screenshot and the output I get from running the settings file in the settings app package in the hope that it'll shed some light on the problem.
http://postimg.org/image/4goidlpc3/
This is the output of the HDSPe settings package file...
Last login: Sat Oct 12 18:59:04 on console
bryans-Mac-Pro:~ bryan$ /Applications/HDSPe\ Settings.app/Contents/MacOS/HDSPe\ Settings ; exit;
2013-10-12 19:20:30.700 HDSPe Settings[382:707] *** Assertion failure in -[NSTextFieldCell _objectValue:forString:errorDescription:], /SourceCache/AppKit/AppKit-1187.40/AppKit.subproj/NSCell.m:1532
2013-10-12 19:20:30.701 HDSPe Settings[382:707] An uncaught exception was raised
2013-10-12 19:20:30.701 HDSPe Settings[382:707] Invalid parameter not satisfying: aString != nil
2013-10-12 19:20:30.703 HDSPe Settings[382:707] (
0 CoreFoundation 0x97ee0e8b __raiseError + 219
1 libobjc.A.dylib 0x98e9c52e objc_exception_throw + 230
2 CoreFoundation 0x97e40698 +[NSException raise:format:arguments:] + 136
3 Foundation 0x97214364 -[NSAssertionHandler handleFailureInMethod:object:file:lineNumber:description:] + 116
4 AppKit 0x94db3b48 -[NSCell _objectValue:forString:errorDescription:] + 183
5 AppKit 0x94db3a87 -[NSCell _objectValue:forString:] + 55
6 AppKit 0x94db39f1 -[NSCell setStringValue:] + 50
7 AppKit 0x94e49965 -[NSControl setStringValue:] + 116
8 HDSPe Settings 0x000071f1 -[Controller initDialog] + 3287
9 HDSPe Settings 0x000074ca -[Controller resetCards] + 234
10 HDSPe Settings 0x00007518 -[Controller awakeFromNib] + 70
11 libobjc.A.dylib 0x98ea9586 -[NSObject performSelector:] + 62
12 CoreFoundation 0x97e375b4 -[NSSet makeObjectsPerformSelector:] + 228
13 AppKit 0x94d96f11 -[NSIBObjectData nibInstantiateWithOwner:topLevelObjects:] + 1180
14 AppKit 0x94d75472 loadNib + 373
15 AppKit 0x94d7484a +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 233
16 AppKit 0x94ec58a4 +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 154
17 AppKit 0x94d7451f +[NSBundle(NSNibLoading) loadNibNamed:owner:] + 709
18 AppKit 0x94d70398 NSApplicationMain + 447
19 HDSPe Settings 0x00001ed6 start + 54
2013-10-12 19:20:30.703 HDSPe Settings[382:707] *** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'Invalid parameter not satisfying: aString != nil'
*** Call stack at first throw:
Trace/BPT trap: 5
logout
[Process completed]
Hope someone can help.
