Topic: TMFX feature request 8 band EQ on Main output
MC, I've been playing around with DIRAC this week and also been double checking measurements with REW using an UMIK usb mic and I've found that the TMFX works REALLY REALLY well as a room EQ solution.
Only 1 pitfall, IT DOESN'T HAVE ENOUGH BANDS
would it be possible to expand the (main) EQ to an 8 or 12 band version?
The application is killer, non invasive LATENCY FREE room EQ directly on you master bus Always any time, to be turned on/off by the click of an knob. It saves me €400 for DIRAC, which BTW is not ideal for realtime work because of it's latency and ASIO routing. would this be possible?
www.analoguemastering.com
Re: TMFX feature request 8 band EQ on Main output
More bands would be great but a higher Q value is needed for room correction (0.01 of an octave would be good).  I would really like to see more Q, even with the current 3 bands.
Thanks.
When i let REW calculate manual filters the all match with the reach of the Q in TMFX
