Topic: ADI-2 QUESTION
I've bought an adi-2 , really great converter  but i have a question.
What is the the right  connection flow?
Now it's connect with projectmix I/O spdif and works fine, but so I use only the DA stage right?
WHy if I connect the project mix analog out , I can't here nothing from the adi-2 analog out? I see the 4dbu signal in the input monitor, but can't hear anything..I have to use spdif out for output to hear...
I'm confused. What is the right hook-up scheme to use the adi 2 correctly?
THanks
M.
Re: ADI-2 QUESTION
Its a 2 channel AD and DA
Analog In -> Digital Out
Digital In -> Analog Out
You probably have no reason to use your ProjectMix Stereo Out any more since you are bypassing the mediocre ProjectMix converters and instead using the DA stage of the ADI-2.
Likewise for recording 1 or 2 channel sources at line level then use the AD stage of the ADI-2
http://mastering.subvertcentral.com
http://www.peparecords.com
