Re: Bugs in latest USB driver 1.114
First driver I used was 1.114 and that was on the Windows 10 (1709), I don't remember so much in detail now, however it was working fine when it was set to 1 WDM Devices and I set 1+2 RME Speakers to be a default (Windows was setting this as a stereo by default).
Reading the manual, I read that I shouldnt use Babyface as a default device in windows and since i like to have systems sounds I was looking for a workaround. I found that updating the Windows I can get the audio routing settings so I did.
I set built in card as a default device and only routed Chrome and Spotify to Babyface. (Set to 1 WDM Devices so only 1+2 was active) and as a results mono singals were always sent to 3/4 even it was disabled in WDM Devices in the driver. I didnt like it and I started to play with windows WDM settings and realized that setting it to stereo works, however Windows was chaning the settings every restart and I also had a very annoying issue when the audio from Chrome was getting ~10dB lower then spotify(I had to go to settings and press stereo again in order to achieve same volume in both). Thinking that headphones will be always stereo I started using the workaround mentioned in previous postand it worked well.
I updated to 1.164 from the website
Seeing the new driver I thought about updating to use it only with 1 WDM device, however it became quite problematic, the WDM wasnt so stable anymore, I heard glitches - especially in Google Chrome or playing audio from both from the same time.
If the error counter only relates to USB hmm maybe that could be an issue, I am planing to perform a clean instalation of Windows soon, as well as clean my computer inside including contacts and stuff so that may be worth giving a try. So I may be able to report more when I am done with it
