Topic: MADI compatibility UFX+
Hello!
I am trying to get MADI (56) from old DASH-recorders (STUDER D827, SONY 3324S) in to UFX+. There are few problems. The 3324S has been just maintained and LAWO's measuring/playback monitoring instrument tells that everything is fine with 3324S's MADI out. How ever UFX+ can't lock to MADI. Are there any limitations how strong in mV can the MADI signal be in UFX+ input?Manual tells that the minimum voltage is 180 mVpp for UFX+.
UFX+ locks to STUDER D827's MADI just fine but the signal is distorted and sounds like the packages are not there in a decent order. What is the package bit depth with UFX+ ? We use 32bit (24 for audio, 8 for rest), there is a possibility to have 24 bit, and if so, can it be changed ?
Cheers!
Niko
