Topic: Fireface 800 and MADI
Hello, hope this is the right place for this question...
I've got a MADIFACE XT and a ADI 648 with 4 ADI-8 DS connected via ADAT to the 648; now the question is: since I have also a Fireface800, may I connect it to the ADI-648? Should I simply connect it via ADAT or there's some other procedure I should follow? Thanks in advance,
Franco.
Re: Fireface 800 and MADI
You can use the FF800 as analog AD/DA via ADAT, even in stand-alone mode if you flash the correct clock and mixer settings into it.
Thank you for the answer.
So, if I've understood correctly I can connect the ff800 to the adi648 via ADAT like the other ADI8s and (the fireface) will take the clock from the madiface via ADAT (just like the ADI8); I guess in the Totalmix I'll see its channels.
And, I may use it in stand alone mode even via firewire but not sure it will be synchronized with the madiface xt that's connected via USB.
Sorry if I repeat the same things twice or more but I want to be sure I'm not going to mess things up.
Thanks again, Franco.
Stand-alone mode means NO FireWire.
