Topic: ADI2 problem
i bought a used adi2 dac and i use it with digital output from my motherboard with  Realtek® ALC1150 Codec ... the problem is that  one channel is a lot louder than other, the left output of dac is different... if i correct it with balance options of mixer there is no problems and the output is good in both channel.
I tried coaxial and optical , same problem.
I change cable and monitor, same output same problem.
What is the problem, i'm fear of some output problem in the left channel that is less loud than right.
Re: ADI2 problem
Manual page 27. Do the reset described there:
https://archiv.rme-audio.de/download/adi2dac_e.pdf
If the problem stays revers-plug the output cables only on the DAC. If the level stays low on the same channel the problem is your amp or speakers.
Re: ADI2 problem
http://www.rme-audio.de/en/products/adi_2.php
I have thi one, i dont think i can reset
Re: ADI2 problem
You wrote "adi2 dac" in Posting #1. That was misleading, because there is also a new product called ADI-2 DAC ;-)
http://www.rme-audio.de/en/products/adi_2-dac.php
Sorry I don't know if also the ADI-2 has some reset procedures. I would guess not, because it has only a few knobs and encoders in the front, no deep configuration menues with lot of settings.
5
Re: ADI2 problem
An older ADI-2 (not DAC) might have problems with dryed-out capacitors at the outputs. That would be easy to repair.
Re: ADI2 problem
youre talk about change capacitors with new one?
7
Re: ADI2 problem
Sure. If that is the culprit.
Re: ADI2 problem
I found a new problem, a noise without signal is more than usual and it stop after around 10second of silence. No noise if i use -10dbv output. I'm using optical in.
