1 (edited by alonzo86 2019-08-17 13:21:38)
Topic: Considering ADI-2 PRO, Got Some Questions.
Hello guys,
I'm a HDSP 9652 user, and I would like to continue with RME in the future.
I'm shopping for a new PC build, and I can't find a suitable motherboard with PCI to continue using my 9652, although a PCIe to PCI converter could work.
Anyways, I'm shopping for a new hi quality AD/DA, and monitor controller (to be used with 2 pairs of speakers ), and possible room correction (was looking at miniDSP devices) for a slight spectrum correction of an already treated room. Then I saw there is ADI-2 Pro with all the features I need.
My questions are:
1. Are drivers for ADI-2 PRO stellar and fast as all other RME units, I guess they can't be as fast as PCI/PCIe line, but are they same stability -speed as Fireface 802, UFX, Babyface and other RME devices so I can use it just via USB without need for 9652 or Raydat or something similar ?
2. Can these two pair of line-outs be used for two pair of speakers, and can they be switched via front control panel of the unit so I don't need another monitor controller in the path?
3. Could I hook up an external 8 channel AD converter via ADAT and have a total of 10 analog ins 44/48 khz, or it's a just 2 channel ADAT interface ? As far as I know adat support 8 channels 44/48 or am I wrong here?
This 3rd request is not that important, I'm more concern about first two things.
If all of these 3 criteria are satisfied, I'll probably cop it.
Re: Considering ADI-2 PRO, Got Some Questions.
ADI-2 Pro/* do not have TotalmixFX.
I recommend a combination of recording interface with TM FX and ADI-2 Pro/*.
I wrote a blog article how to integrate the ADI-2
Pro/* into such a setup. I  personally use a combination of UFX+ and ADI-2 Pro FS BE.
http://www.tonstudio-forum.de/blog/inde … our-Setup/
The ADI-2 Pro FS has 1 A/D and 2 D/A converter.
To your questions:
XLR and TS outputs are not separate, see manual.
But you can have separate settings between ie
- monitors and phones or
- two different phones
and IIRR the device remembers all settings for
- Analog OUT 1/2 (XLR or phones) and
- AN Out 3/4 for phones
The device can only read the first two channels out of an ADAT stream and also supports optical S/PDIF.
The combination of RME recording interface with TM FX and ADI-2 Pro FS is excellent and I can recommend it much.
