Topic: Dim Function
Hello, again it's great to have the Dim in the last firmware.
But may be there's a bug, as if it's clever to stay at the dim level if we move the output level down, there's a jump of twenty db if we move the output level up. It would be logical to stay at the dim level like when we move the level down.
Of course it would be nice to be able to move the Dim level to a smaller value in the future. smile
But 20 db is the basic good one.
Finally it's cool to see the dim near 1/2 when it's engaged.
Re: Dim Function
Logic can be different wink
Our logic says that moving further down the Dim value was not enough. Moving up means that Dim is not needed anymore. If Dim stays active whatever you do it will soon cause confusing cases where Dim is active all the time, unnoticed.
3 (edited by doof 2019-10-05 18:19:21)
Re: Dim Function
Hello, ok sorry.
In my workflow i use the dim for some seconds than i press the switch to go back to full level,
if i don't switch back an stay with the dim i forget that it's engaged, that's why it was logic for me.
I was thinking about automatically leave the dim, like when we turn the level down.
Re: Dim Function
about the DIM function, maybe I missed it, but is there any way to set the DIM level, other than -20 dB?
That would be really nice.
Thanks.
5
Re: Dim Function
DIM is not adjustable.
Re: Dim Function
Well, that would be a great future feature IMO smile
Thanks for the answer!
