Topic: Recording Tracks don't NULL properly, anyone ?
Guys, could really use some help on this one, I'm not quite as sharp in the digital realm as some of you younger guys out there...
Using FF400 with Sonar (I know, a bit old) and a Kemper Profiler. Running SPDIF to Kemper (as master) I reamp a direct (dry) guitar track twice and it results in a pair of tracks that usually don't NULL when one is phase reversed. Maybe 1 out of 5 times it will work, the rest fail. Does anyone have any idea why this might be? How might I narrow down where the problem is (Sonar, RME or Kemper) ? Can I simply connect a SPDIF cable from output back to input in order to remove the Kemper from the testing equation? Or, if anyone has a Kemper (regardless of DAW or interface) and could try this test it would be helpful in maybe eliminating that variable. Just don't forget to turn Constant Latency On.
Sonic
