1 (edited by oglow 2019-10-15 15:39:26)
Topic: Speaker B set to single output?
HI,
Is there any way to set the speaker B to a single output i.e AN 3 and not only AN3/4
I have an ARC and love the speaker B push button and utilise the snapshots a lot already but have recently switched to just a single "B monitor" as I only really used my old stereo set for checking mono with bass challenged speakers.
Would love to be able to do it without setting up a snapshot, as when doing it that way, the speaker B doesnt follow the volume state of Main outputs. PLus AN 4 is justbeing wasted.
Surely I'm not the only one using a mono speaker as speaker B and don't want to lose an analog output unneededly.
Re: Speaker B set to single output?
Speaker B only follows the volume state of Main Out, if you press "link" button at Speaker B's fader
You can create a Fader group for a mono output channel and Main Out.
Why wasted ? Also Speaker B uses some other outputs ...
any result with this? I want to use speaker B for a single mixcube and ARC
I'm also using speaker B as a mono output. But I made a stereo to mono adaptercable so I don't have to click 2 buttons. So when I hit speaker B I instantly get a down mixed version on my mono speaker. Works great
This is a pretty old topic...
Are there any news/updates/ideas?
Basically, I'm going to purchase a UFX III and consider the ARC USB, to get rid of my monitor controller between the interfaces and amps. Seems to make sense, better sound etc..
All I'm using on the monitor controller is DIM, and a mono sub out, that I switch on while switching OFF the output to my main speakers, to check my mix on a mixcube.
I'd love to set Speaker B to a single output on the UFX III, to my mixcube. Is that nowadays possible?
Use speaker B for the stereo loudspeakers and use the Main-out (set to mono with the mono button in the control room) for the mix-cube
mmm, I'd prefer using the XLR outs for my main monitors, and ideally 1 additional output for the mixcube... Thanks for the advice in any case!
I’ve been on this journey too. I ended up getting a TRS to XLR Stereo to Mono cable..
Before I did this I used ARC with default dim button reconfigured for mono. I could then press Speaker B and Dim at the same time when to switching to the Avantone.
Si
Alright, so no better option than pressing Mono or making a Y cable.. Which I may do then. Too bad, I guess it's a need that could be addressed in software by RME and seems a common one.
Thanks!
That can remain, just assign it in the control room to Speaker B instead main-out.
Isn't the Mono button in Control Room affecting Speaker B as well?
Yes…
Same "problem" here. Neumann KH 310 for Main stereo output and single Avantone (Speakers B) to check the mix in Mono.
Would be great that the "Mono" button could be assigned per speaker output and not as a global setting for all speakers outputs.
Now requires two actions to chek your mix in mono on the ARC, first press "Speakers B", then press "Mono". And again press "Speakers B" and press "Mono" to go back to your Main stereo Mix.
I'll research the Y mono cable, but I guess is just a workaround and I worry that I can damage the RME Fireface UFX II by connecting such a cable.
You can loop the output of Speaker B back into an input using a cable. Ideally, use a digital input/output that you're not currently using.
For example, Speaker B is normally set to analog 3/4 output and you are not using ADAT. In the control room, set Speaker B to ADAT 1-2. Then connect an ADAT cable from ADAT out to ADAT IN. Next, set the "width" in the input channel to 0 and route this input channel to analog out 3/4.
When you then press Speaker B, you'll get mono output from channel analog 3/4. Use only one output.
Audio AG Support
