Yes .. and using digital data transfer would have the advantage, that audio stays digital / unaltered up to the D/A converter of the ADI-2 which are a little better compared to those of the UC when looking at the technical data of the D/A section in the manual.
I would choose optical data transfer by TOSLINK cable, because then you have
- galvanic isolation on top and
- the flexibility in placement of the ADI-2, because TOSLINK cables can be up to 15m long (sometimes even 20m).
Assuming your UC is clock master you only need to set the ADI-2 to get clock from optical, see front switch "clock input".
I can recommend you this TOSLINK cable, never had quality issues with them: https://www.thomann.de/de/mutec_optisches_kabel_2m.htm
The plugs sit tight, but still can be plugged out easily and and the cable is not too thick. I am using this cable in different length, the longest is 15m between UFX+ and ADI-2 DAC and it can be used up to 192 kHz without any issues.
Please note: too thick TOSLINK cables (like this one from Sommer Cable: https://www.thomann.de/de/sommer_cable_ … el_3m.htm) exert unnecessary transverse forces on the plug and cannot be laid so easily because they like to form loops. For example, if you want to lay several TOSLINK cables for a RayDAT card, then you can easily twist thinner cables together, this is not possible with thicker cables.
