Topic: Mid Side Monitoring (including Muting)
Hi RME forum,
I have spent quite a bit of time setting up DIGICheck for metering which is looking amazing.
However I would like to quickly Mute the MID or the SIDE of the signal (and possibly L and R). What is the most efficient way I could do this using Totalmix / DIGICheck?
My routing is such that I am using the AN1/AN2 as well as separate channels such as ADAT3/4 etc. to monitor different applications on different routes. I have set up a template for each output routing, however I am stuck on how to Mute just the Mid (L+R) or Side (L-R) of whatever signal is being monitored. (In the meters I was able to configure this ok).
I have seen a clip of someone using TouchOSC to automate this
