1 (edited by Yannick Bisson 2019-11-03 15:31:26)
Topic: @ RME Support: iMac Pro (T2 Chip) + Mojave + UFX = Audio glitches.
I have an iMac Pro with Mojave 10.14.6 (not Catalina), and I am having a bug:  the UFX gets audio gltiches / interruptions every now and then.
I search a bit on the web and it seems that some audio card has a problem with the new T2 Chips when used in USB port.
I followed some advice about disable "time sync", resetting the SMC, etc.. ect...  I also used a Thunderbolt 3 / USB-C adapter to plug the USB cable directly into a Thunderbolt 3 port... but no success.
What Can I Do?  I am at loss,  and being interrupted while recording is really frustrating.
Thanks for coming back soon.
Yann
PS: Latest driver version installed : 3.18,  Firmware : 360.   Ableton Live 10.1.2
Re: @ RME Support: iMac Pro (T2 Chip) + Mojave + UFX = Audio glitches.
Do you update both drivers and firmware ?
Bertrand Allaume
So I had the audio glitch again, and here is the detail:
default    08:40:29.679575 -0500    sharingd    Nearby didDiscoverType 1 UUID 7ED4ABD0-113C-4EB2-8DFE-BFA20D907BA1 info {
    WPNearbyKeyDeviceAddress = <80b03de2 6487>;
    WPNearbyKeyManufacturerData = <4c001005 131873b5 05>;
    WPNearbyKeyPaired = 0;
    WPNearbyKeyRSSI = "-54";
    kDeviceChannel = 37;
default    08:40:37.125488 -0500    locationd    {"msg":"kCLConnectionMessageWatchdog", "event":"activity", "this":"0x7fc25840f2e0", "registrationRequired":0, "registrationReceived":1}
default    08:40:37.175603 -0500    locationd    {"msg":"kCLConnectionMessageWatchdog", "event":"activity", "this":"0x7fc259a1a210", "registrationRequired":0, "registrationReceived":1}
default    08:40:37.176506 -0500    locationd    {"msg":"kCLConnectionMessageWatchdog", "event":"activity", "this":"0x7fc259d11230", "registrationRequired":0, "registrationReceived":1}
default    08:40:37.562568 -0500    locationd    {"msg":"kCLConnectionMessageWatchdog", "event":"activity", "this":"0x7fc25990fe60", "registrationRequired":0, "registrationReceived":1}
default    08:40:37.846211 -0500    kernel    outCallback (7) - returned status: e00002be
default    08:40:37.846219 -0500    kernel    outCallback (7) - frame 0 returned status: e00002be, restart requested
default    08:40:37.846221 -0500    kernel    outCallback (7) - frame 1 returned status: e00002be, restart requested
default    08:40:37.846224 -0500    kernel    outCallback (7) - frame 2 returned status: e00002be, restart requested
default    08:40:37.897468 -0500    locationd    {"msg":"kCLConnectionMessageWatchdog", "event":"activity", "this":"0x7fc248b00c90", "registrationRequired":0, "registrationReceived":1}
default    08:40:37.956530 -0500    Dock    notifyBestAppChanged:(null) UASuggestedActionType=0 <private>/<private> opts=(null) when=Tue Nov  5 08:40:37 2019 confidence=0 from=<private>/<private>
default    08:40:38.092202 -0500    kernel    + IOAudioEngine[<private>]::stopAudioEngine()
default    08:40:38.092239 -0500    kernel    +-IOAudioEngine[<private>]::setState(0x0. oldState=0x1)
default    08:40:38.092250 -0500    kernel    + IOAudioDevice[<private>]::audioEngineStopped() - numRunningAudioEngines = 1
default    08:40:38.092252 -0500    kernel    + IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = 00
default    08:40:38.092253 -0500    kernel    + IOAudioDevice[<private>]::initiatePowerStateChange(0x0) - current = 2 - pending = 1
default    08:40:38.092254 -0500    kernel    + IOAudioDevice[<private>]::protectedCompletePowerStateChange() - current = 2 - pending = 1
default    08:40:38.092256 -0500    kernel    - IOAudioDevice[<private>]::protectedCompletePowerStateChange() - current = 1 - pending = 1 returns 0x0
default    08:40:38.092257 -0500    kernel    - IOAudioDevice[<private>]::initiatePowerStateChange(0x0) - current = 1 - pending = 1 returns 0x0
default    08:40:38.092258 -0500    kernel    - IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = 00
default    08:40:38.092259 -0500    kernel    - IOAudioDevice[<private>]::audioEngineStopped() - numRunningAudioEngines = 0
default    08:40:38.092259 -0500    kernel    - IOAudioEngine[<private>]::stopAudioEngine() returns 0x0
default    08:40:38.092261 -0500    kernel    + IOAudioEngine[<private>]::startAudioEngine(state = 0)
default    08:40:38.092262 -0500    kernel    + IOAudioDevice[<private>]::audioEngineStarting() - numRunningAudioEngines = 0
default    08:40:38.092264 -0500    kernel    + IOAudioDevice[<private>]::initiatePowerStateChange(0x0) - current = 1 - pending = 2
default    08:40:38.092264 -0500    kernel    + IOAudioDevice[<private>]::protectedCompletePowerStateChange() - current = 1 - pending = 2
default    08:40:38.092265 -0500    kernel    - IOAudioDevice[<private>]::protectedCompletePowerStateChange() - current = 2 - pending = 2 returns 0x0
default    08:40:38.092266 -0500    kernel    - IOAudioDevice[<private>]::initiatePowerStateChange(0x0) - current = 2 - pending = 2 returns 0x0
default    08:40:38.092267 -0500    kernel    - IOAudioDevice[<private>]::audioEngineStarting() - numRunningAudioEngines = 1
default    08:40:38.092268 -0500    kernel    - IOAudioEngine[<private>]::stopEngineAtPosition(0,0)
default    08:40:38.092269 -0500    kernel    +- IOAudioEngine[<private>]::resetStatusBuffer()
default    08:40:38.092904 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x4,   arg0 0x0, arg1 0x0, arg2 0x0 arg3 0x0
default    08:40:38.092907 -0500    kernel      scalarInputCount=0x0  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.095345 -0500    kernel    +-IOAudioEngine[<private>]::setState(0x1. oldState=0)
default    08:40:38.095351 -0500    kernel    - IOAudioEngine[<private>]::getTimerInterval()
default    08:40:38.095357 -0500    kernel    - IOAudioEngine[<private>]::startAudioEngine() returns 0x0
default    08:40:38.095364 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095368 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095379 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095392 -0500    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    08:40:38.095443 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113E4D000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.095485 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095522 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113E6E000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.095537 -0500    kernel      checking input
default    08:40:38.095554 -0500    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.095567 -0500    kernel      checking against 0x113dd0000
default    08:40:38.095570 -0500    kernel      checking input
default    08:40:38.095581 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.095596 -0500    kernel      searching for sourceBuffer 0x113e88000
default    08:40:38.095598 -0500    kernel      checking against 0x113e2c000
default    08:40:38.095613 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113EA9000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.095614 -0500    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.095623 -0500    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0xf6)
default    08:40:38.095624 -0500    kernel      searching for sourceBuffer 0x113ea9000
default    08:40:38.095625 -0500    kernel      checking against 0x113dd0000
default    08:40:38.095625 -0500    kernel      checking against 0x113df1000
default    08:40:38.095626 -0500    kernel      checking against 0x113e02000
default    08:40:38.095627 -0500    kernel      checking against 0x113e0b000
default    08:40:38.095627 -0500    kernel      checking against 0x113e2c000
default    08:40:38.095628 -0500    kernel      checking input
default    08:40:38.095628 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095630 -0500    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    08:40:38.095630 -0500    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095639 -0500    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    08:40:38.095639 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.095642 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113DD0000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.095643 -0500    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.095653 -0500    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0xf6)
default    08:40:38.095653 -0500    kernel      searching for sourceBuffer 0x113dd0000
default    08:40:38.095654 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095655 -0500    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    08:40:38.095656 -0500    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095664 -0500    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    08:40:38.095665 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.095669 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113DF1000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.095669 -0500    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.095678 -0500    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0xf6)
default    08:40:38.096041 -0500    powerd    Process coreaudiod.150 TurnedOff PreventUserIdleSystemSleep "com.apple.audio.de_RME_driver_USBAudioEngine:167F8ED.context.preventuseridlesleep" age:00:32:41  id:4295000953 [System: PrevIdle DeclUser kDisp]
default    08:40:38.095680 -0500    kernel      searching for sourceBuffer 0x113df1000
default    08:40:38.095680 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095681 -0500    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    08:40:38.095682 -0500    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095687 -0500    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    08:40:38.095689 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.095695 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113E02000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.095697 -0500    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.095706 -0500    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0xf6)
default    08:40:38.095706 -0500    kernel      searching for sourceBuffer 0x113e02000
default    08:40:38.095708 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095708 -0500    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    08:40:38.095709 -0500    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095718 -0500    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    08:40:38.095719 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.095722 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113E0B000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.095723 -0500    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.095734 -0500    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0xf6)
default    08:40:38.095734 -0500    kernel      searching for sourceBuffer 0x113e0b000
default    08:40:38.095735 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095736 -0500    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    08:40:38.095737 -0500    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095746 -0500    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    08:40:38.095748 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.095750 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113E2C000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.095752 -0500    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.095761 -0500    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0xf6)
default    08:40:38.095761 -0500    kernel      searching for sourceBuffer 0x113e2c000
default    08:40:38.095764 -0500    kernel    +- IOAudioEngineUserClient[<private>]::removeBufferSet(<private>)
default    08:40:38.095765 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095765 -0500    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    08:40:38.095766 -0500    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.095774 -0500    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    08:40:38.095775 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.096937 -0500    dasd    Trigger: <private> is now [0]
default    08:40:38.097344 -0500    dasd    Trigger: <private> is now [0]
default    08:40:38.101075 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1181:CheckForChanges:  ===================================
default    08:40:38.101098 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1182:CheckForChanges:  HALS_DefaultDeviceManager::CheckForChanges:                 --->>>
default    08:40:38.101115 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1251:CheckForChanges:  HALS_DefaultDeviceManager::CheckForChanges:            'dIn ' --->>>
default    08:40:38.101130 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1591:UpdateDefaultDevice:  HALS_DefaultDeviceManager::UpdateDefaultDevice:        'dIn ' --->>>
default    08:40:38.101146 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1612:FindPreferredDefaultDevice:  HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'dIn ' --->>>
default    08:40:38.101295 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1642:FindPreferredDefaultDevice:  HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'dIn ' | found preferred[0] 226: 'AppleUSBAudioEngine:Native Instruments:Maschine MK3:E5D2F42C:1,2'/''
default    08:40:38.101310 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1649:FindPreferredDefaultDevice:  HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'dIn ' <<<---
default    08:40:38.101324 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1604:UpdateDefaultDevice:  HALS_DefaultDeviceManager::UpdateDefaultDevice:        'dIn ' <<<---
default    08:40:38.101337 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1328:CheckForChanges:  HALS_DefaultDeviceManager::CheckForChanges:            'dIn ' <<<---
default    08:40:38.101350 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1329:CheckForChanges:  -----------------------------------
default    08:40:38.101364 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1251:CheckForChanges:  HALS_DefaultDeviceManager::CheckForChanges:            'dOut' --->>>
default    08:40:38.101379 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1591:UpdateDefaultDevice:  HALS_DefaultDeviceManager::UpdateDefaultDevice:        'dOut' --->>>
default    08:40:38.101395 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1612:FindPreferredDefaultDevice:  HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'dOut' --->>>
default    08:40:38.101479 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1642:FindPreferredDefaultDevice:  HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'dOut' | found preferred[0] 104: 'BuiltInSpeakerDevice'/'ispk'
default    08:40:38.101494 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1649:FindPreferredDefaultDevice:  HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'dOut' <<<---
default    08:40:38.101507 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1604:UpdateDefaultDevice:  HALS_DefaultDeviceManager::UpdateDefaultDevice:        'dOut' <<<---
default    08:40:38.101521 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1328:CheckForChanges:  HALS_DefaultDeviceManager::CheckForChanges:            'dOut' <<<---
default    08:40:38.101537 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1329:CheckForChanges:  -----------------------------------
default    08:40:38.101741 -0500    tccd    PID[206] is checking access for target PID[453]
default    08:40:38.101550 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1251:CheckForChanges:  HALS_DefaultDeviceManager::CheckForChanges:            'sOut' --->>>
default    08:40:38.101594 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1591:UpdateDefaultDevice:  HALS_DefaultDeviceManager::UpdateDefaultDevice:        'sOut' --->>>
default    08:40:38.101639 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1612:FindPreferredDefaultDevice:  HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'sOut' --->>>
default    08:40:38.101718 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1642:FindPreferredDefaultDevice:  HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'sOut' | found preferred[0] 104: 'BuiltInSpeakerDevice'/'ispk'
default    08:40:38.101734 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1649:FindPreferredDefaultDevice:  HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'sOut' <<<---
default    08:40:38.101747 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1604:UpdateDefaultDevice:  HALS_DefaultDeviceManager::UpdateDefaultDevice:        'sOut' <<<---
default    08:40:38.101780 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1328:CheckForChanges:  HALS_DefaultDeviceManager::CheckForChanges:            'sOut' <<<---
default    08:40:38.101820 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1329:CheckForChanges:  -----------------------------------
default    08:40:38.101854 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1251:CheckForChanges:  HALS_DefaultDeviceManager::CheckForChanges:            'shrd' --->>>
default    08:40:38.101898 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1591:UpdateDefaultDevice:  HALS_DefaultDeviceManager::UpdateDefaultDevice:        'shrd' --->>>
default    08:40:38.101922 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1612:FindPreferredDefaultDevice:  HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'shrd' --->>>
default    08:40:38.102006 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1642:FindPreferredDefaultDevice:  HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'shrd' | found preferred[0] 104: 'BuiltInSpeakerDevice'/'ispk'
default    08:40:38.102021 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1649:FindPreferredDefaultDevice:  HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'shrd' <<<---
default    08:40:38.102034 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1604:UpdateDefaultDevice:  HALS_DefaultDeviceManager::UpdateDefaultDevice:        'shrd' <<<---
default    08:40:38.102045 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1328:CheckForChanges:  HALS_DefaultDeviceManager::CheckForChanges:            'shrd' <<<---
default    08:40:38.102058 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1329:CheckForChanges:  -----------------------------------
default    08:40:38.102090 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1189:CheckForChanges:  HALS_DefaultDeviceManager::CheckForChanges:                 <<<---
default    08:40:38.102117 -0500    coreaudiod    HALS_DefaultDeviceManager.cpp:1190:CheckForChanges:  ===================================
default    08:40:38.112986 -0500    trustd    OCSPResponse: single response has extension(s).
default    08:40:38.114192 -0500    trustd    asynchronously fetching CRL (http://crl.apple.com/root.crl) for client (tccd[277]/0#-1 LF=0)
default    08:40:38.114237 -0500    trustd    cert[2]: AnchorTrusted =(leaf)[force]> 0
default    08:40:38.123919 -0500    tccd    -[TCCDAccessIdentity staticCode]: static code for: identifier com.ableton.live, type: 0: 0x7fabc6a0a730 at /Applications/Ableton Live 10.1 Beta.app
default    08:40:38.132478 -0500    trustd    OCSPResponse: single response has extension(s).
default    08:40:38.133737 -0500    trustd    asynchronously fetching CRL (http://crl.apple.com/root.crl) for client (tccd[277]/0#-1 LF=0)
default    08:40:38.133779 -0500    trustd    cert[2]: AnchorTrusted =(leaf)[force]> 0
default    08:40:38.137601 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x0,   arg0 0x0, arg1 0x113e4d000, arg2 0x20010 arg3 0xf6
default    08:40:38.137607 -0500    kernel      scalarInputCount=0x4  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.137628 -0500    kernel    + IOAudioEngineUserClient::registerBuffer64 0x0 0x113e4d000 0x20010 0xf6
default    08:40:38.137631 -0500    kernel    + IOAudioEngineUserClient::safeRegisterClientBuffer64 <private>
default    08:40:38.137633 -0500    kernel    + IOAudioEngineUserClient[<private>]::registerClientBuffer64  (<private>[1], 0x113e4d000, 0x20010, 0xf6)
default    08:40:38.137828 -0500    kernel      null clientBufferSetList
default    08:40:38.137889 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer before offset: <private>, offset size: 16
default    08:40:38.137890 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer after offset: <private>
default    08:40:38.137891 -0500    kernel      input
default    08:40:38.137910 -0500    kernel    + IOAudioEngineUserClient::safeRegisterClientBuffer64 <private>
default    08:40:38.137921 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer before offset: <private>, offset size: 16
default    08:40:38.137942 -0500    kernel    + IOAudioEngineUserClient::registerBuffer64 0x3 0x113e88000 0x20010 0xf6
default    08:40:38.137972 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer before offset: <private>, offset size: 16
default    08:40:38.137973 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer after offset: <private>
default    08:40:38.137974 -0500    kernel      assigning  clientBufPtr->mAudioClientBuffer32.mNextBuffer32 <private>
default    08:40:38.137992 -0500    kernel    + IOAudioEngineUserClient::registerBuffer64 0x4 0x113ea9000 0x20010 0xf6
default    08:40:38.138019 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer before offset: <private>, offset size: 16
default    08:40:38.138021 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer after offset: <private>
default    08:40:38.138020 -0500    kernel      input
default    08:40:38.138039 -0500    kernel    + IOAudioEngineUserClient::registerBuffer64 0x5 0x113dd0000 0x20010 0xf6
default    08:40:38.138080 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer before offset: <private>, offset size: 16
default    08:40:38.138080 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer after offset: <private>
default    08:40:38.138081 -0500    kernel      output
default    08:40:38.138087 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x0,   arg0 0x6, arg1 0x113df1000, arg2 0x10010 arg3 0xf6
default    08:40:38.138098 -0500    kernel    + IOAudioEngineUserClient::registerBuffer64 0x6 0x113df1000 0x10010 0xf6
default    08:40:38.138125 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer after offset: <private>
default    08:40:38.138144 -0500    kernel    + IOAudioEngineUserClient::safeRegisterClientBuffer64 <private>
default    08:40:38.138173 -0500    kernel    - IOAudioEngineUserClient::registerBuffer64 0x7 0x113e02000 0x8010 0xf6 returns 0x0
default    08:40:38.138222 -0500    kernel    - IOAudioEngineUserClient::safeRegisterClientBuffer64  returns 0x0
default    08:40:38.138228 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x0,   arg0 0x9, arg1 0x113e2c000, arg2 0x20010 arg3 0xf6
default    08:40:38.138229 -0500    kernel      scalarInputCount=0x4  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.138238 -0500    kernel    + IOAudioEngineUserClient::registerBuffer64 0x9 0x113e2c000 0x20010 0xf6
default    08:40:38.138239 -0500    kernel    + IOAudioEngineUserClient::safeRegisterClientBuffer64 <private>
default    08:40:38.138240 -0500    kernel    + IOAudioEngineUserClient[<private>]::registerClientBuffer64  (<private>[23], 0x113e2c000, 0x20010, 0xf6)
default    08:40:38.138266 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer before offset: <private>, offset size: 16
default    08:40:38.138267 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer after offset: <private>
default    08:40:38.138267 -0500    kernel      output
default    08:40:38.138268 -0500    kernel      assigning  clientBufPtr->mAudioClientBuffer32.mNextBuffer32 <private>
default    08:40:38.138268 -0500    kernel      !isOnline
default    08:40:38.138269 -0500    kernel    - IOAudioEngineUserClient::registerClientBuffer64() result 0x0
default    08:40:38.138270 -0500    kernel    - IOAudioEngineUserClient::safeRegisterClientBuffer64  returns 0x0
default    08:40:38.138271 -0500    kernel    - IOAudioEngineUserClient::registerBuffer64 0x9 0x113e2c000 0x20010 0xf6 returns 0x0
default    08:40:38.138272 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.138283 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x3,   arg0 0x0, arg1 0x0, arg2 0x0 arg3 0x0
default    08:40:38.138283 -0500    kernel      scalarInputCount=0x0  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.138294 -0500    kernel    + IOAudioEngineUserClient[<private>]::startClient() - 0
default    08:40:38.138295 -0500    kernel      audioEngine && !isInactive(). State = 1
default    08:40:38.138296 -0500    kernel      audioEngine->getState() != kIOAudioEnginePaused
default    08:40:38.138299 -0500    kernel    +- IOAudioEngineUserClient[<private>]::setOnline(1)
default    08:40:38.138300 -0500    kernel      !isOnline() setting online
default    08:40:38.138301 -0500    kernel    + IOAudioEngine[<private>]::startClient(<private>)
default    08:40:38.138302 -0500    kernel    + IOAudioEngine[<private>]::incrementActiveUserClients() - 0
default    08:40:38.138305 -0500    kernel    + IOAudioEngine[<private>]::startAudioEngine(state = 1)
default    08:40:38.138305 -0500    kernel    - IOAudioEngine[<private>]::startAudioEngine() returns 0x0
default    08:40:38.138306 -0500    kernel    - IOAudioEngine[<private>]::incrementActiveUserClients() - 1 returns 0
default    08:40:38.138307 -0500    kernel    - IOAudioEngine[<private>]::startClient(<private>) returns 0x0
default    08:40:38.138307 -0500    kernel      engine started
default    08:40:38.138308 -0500    kernel      bufferSet <private>
default    08:40:38.138308 -0500    kernel      output clientBuffer <private>
default    08:40:38.138309 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.138311 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.138312 -0500    kernel      output clientBuffer <private>
default    08:40:38.138313 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.138314 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.138315 -0500    kernel      output clientBuffer <private>
default    08:40:38.138315 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.138319 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.138319 -0500    kernel      output clientBuffer <private>
default    08:40:38.138320 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.138321 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.138322 -0500    kernel      output clientBuffer <private>
default    08:40:38.138322 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.138324 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.138325 -0500    kernel      input clientBuffer <private>
default    08:40:38.138325 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.138327 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.138327 -0500    kernel      input clientBuffer <private>
default    08:40:38.138329 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.138330 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.138330 -0500    kernel      input clientBuffer <private>
default    08:40:38.138331 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.138333 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.138333 -0500    kernel      input clientBuffer <private>
default    08:40:38.138334 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.138335 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.138336 -0500    kernel      input clientBuffer <private>
default    08:40:38.138337 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.138338 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.138339 -0500    kernel    - IOAudioEngineUserClient[<private>]::startClient() - 1 returns 0x0
default    08:40:38.138340 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.283479 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x4,   arg0 0x0, arg1 0x0, arg2 0x0 arg3 0x0
default    08:40:38.283484 -0500    kernel      scalarInputCount=0x0  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.283507 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.283511 -0500    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    08:40:38.283519 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.283534 -0500    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.283550 -0500    kernel    - IOAudioEngine[<private>]::stopEngineAtPosition(2,3ff2)
default    08:40:38.283572 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113E4D000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.283589 -0500    kernel      checking against 0x113e2c000
default    08:40:38.283640 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113E6E000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.283654 -0500    kernel      checking against 0x113e02000
default    08:40:38.283656 -0500    kernel      checking input
default    08:40:38.283672 -0500    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.283683 -0500    kernel      checking against 0x113dd0000
default    08:40:38.283687 -0500    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    08:40:38.283696 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.283711 -0500    kernel      searching for sourceBuffer 0x113e88000
default    08:40:38.283715 -0500    kernel      checking against 0x113e2c000
default    08:40:38.283734 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113EA9000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.283735 -0500    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.283744 -0500    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0xf6)
default    08:40:38.283745 -0500    kernel      searching for sourceBuffer 0x113ea9000
default    08:40:38.283746 -0500    kernel      checking against 0x113dd0000
default    08:40:38.283747 -0500    kernel      checking against 0x113df1000
default    08:40:38.283749 -0500    kernel      checking against 0x113e02000
default    08:40:38.283749 -0500    kernel      checking against 0x113e0b000
default    08:40:38.283751 -0500    kernel      checking against 0x113e2c000
default    08:40:38.283751 -0500    kernel      checking input
default    08:40:38.283751 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.283753 -0500    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    08:40:38.283754 -0500    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.283762 -0500    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    08:40:38.283763 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.283766 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113DD0000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.283768 -0500    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.283778 -0500    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0xf6)
default    08:40:38.283779 -0500    kernel      searching for sourceBuffer 0x113dd0000
default    08:40:38.283779 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.283780 -0500    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    08:40:38.283781 -0500    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.283791 -0500    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    08:40:38.283792 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.283795 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113DF1000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.283796 -0500    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.283806 -0500    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0xf6)
default    08:40:38.283806 -0500    kernel      searching for sourceBuffer 0x113df1000
default    08:40:38.283807 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.283808 -0500    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    08:40:38.283808 -0500    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.283816 -0500    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    08:40:38.283817 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.283820 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113E02000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.283821 -0500    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.283830 -0500    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0xf6)
default    08:40:38.283832 -0500    kernel      searching for sourceBuffer 0x113e02000
default    08:40:38.283832 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.283833 -0500    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    08:40:38.283833 -0500    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.283841 -0500    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    08:40:38.283842 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.283845 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113E0B000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.283846 -0500    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.283856 -0500    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0xf6)
default    08:40:38.283857 -0500    kernel      searching for sourceBuffer 0x113e0b000
default    08:40:38.283858 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.283858 -0500    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    08:40:38.283859 -0500    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.283869 -0500    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    08:40:38.283869 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.283873 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x113E2C000, arg1 0xf6, arg2 0x0 arg3 0x0
default    08:40:38.283874 -0500    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.283883 -0500    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0xf6)
default    08:40:38.283884 -0500    kernel      searching for sourceBuffer 0x113e2c000
default    08:40:38.283886 -0500    kernel    +- IOAudioEngineUserClient[<private>]::removeBufferSet(<private>)
default    08:40:38.283886 -0500    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.283887 -0500    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    08:40:38.283888 -0500    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    08:40:38.283896 -0500    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    08:40:38.283897 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.288208 -0500    locationd    {"msg":"kCLConnectionMessageWatchdog", "event":"activity", "this":"0x7fc25840fa40", "registrationRequired":0, "registrationReceived":1}
default    08:40:38.357791 -0500    coreaudiod    HALS_IOContextDescription.cpp:1128:PushStreamUsageToEngines_block_invoke:  IOContext 246: pushing 5 output stream(s) to 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.357817 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: output stream[0] => Disabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.357830 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: output stream[1] => Disabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.357842 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: output stream[2] => Disabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.357854 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: output stream[3] => Disabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.357868 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: output stream[4] => Disabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.357997 -0500    coreaudiod    HALS_IOContextDescription.cpp:1128:PushStreamUsageToEngines_block_invoke:  IOContext 246: pushing 5 input stream(s) to 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.358038 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: input stream[0] => Disabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.358084 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: input stream[1] => Disabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.358190 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: input stream[2] => Disabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.358236 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: input stream[3] => Disabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.358290 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: input stream[4] => Disabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.361118 -0500    coreaudiod    HALS_IOContextDescription.cpp:1128:PushStreamUsageToEngines_block_invoke:  IOContext 246: pushing 5 output stream(s) to 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.361139 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: output stream[0] => Enabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.361151 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: output stream[1] => Enabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.361163 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: output stream[2] => Enabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.361187 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: output stream[3] => Enabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.361198 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: output stream[4] => Enabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.361246 -0500    coreaudiod    HALS_IOContextDescription.cpp:1128:PushStreamUsageToEngines_block_invoke:  IOContext 246: pushing 5 input stream(s) to 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.361259 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: input stream[0] => Enabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.361354 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: input stream[1] => Enabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.361412 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: input stream[2] => Enabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.361431 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: input stream[3] => Enabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.361467 -0500    coreaudiod    HALS_IOContextDescription.cpp:1132:PushStreamUsageToEngines_block_invoke:  IOContext 246: input stream[4] => Enabled: 'de_RME_driver_USBAudioEngine:167F8ED'
default    08:40:38.370159 -0500    tccd    PID[206] is checking access for target PID[453]
default    08:40:38.380855 -0500    trustd    OCSPResponse: single response has extension(s).
default    08:40:38.381976 -0500    trustd    asynchronously fetching CRL (http://crl.apple.com/root.crl) for client (tccd[277]/0#-1 LF=0)
default    08:40:38.382019 -0500    trustd    cert[2]: AnchorTrusted =(leaf)[force]> 0
default    08:40:38.390763 -0500    tccd    -[TCCDAccessIdentity staticCode]: static code for: identifier com.ableton.live, type: 0: 0x7fabc140c080 at /Applications/Ableton Live 10.1 Beta.app
default    08:40:38.399395 -0500    trustd    OCSPResponse: single response has extension(s).
default    08:40:38.400498 -0500    trustd    asynchronously fetching CRL (http://crl.apple.com/root.crl) for client (tccd[277]/0#-1 LF=0)
default    08:40:38.400540 -0500    trustd    cert[2]: AnchorTrusted =(leaf)[force]> 0
default    08:40:38.404192 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x0,   arg0 0x0, arg1 0x113e4d000, arg2 0x20010 arg3 0xf6
default    08:40:38.404198 -0500    kernel      scalarInputCount=0x4  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.404222 -0500    kernel    + IOAudioEngineUserClient::registerBuffer64 0x0 0x113e4d000 0x20010 0xf6
default    08:40:38.404224 -0500    kernel    + IOAudioEngineUserClient::safeRegisterClientBuffer64 <private>
default    08:40:38.404226 -0500    kernel    + IOAudioEngineUserClient[<private>]::registerClientBuffer64  (<private>[1], 0x113e4d000, 0x20010, 0xf6)
default    08:40:38.404229 -0500    kernel      null clientBufferSetList
default    08:40:38.404230 -0500    kernel      did not find clientBufferSetList for ID 0xf6
default    08:40:38.404421 -0500    kernel      null clientBufferSetList
default    08:40:38.404448 -0500    kernel    + IOAudioEngineUserClient::registerBuffer64 0x1 0x113e6e000 0x10010 0xf6
default    08:40:38.404483 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer before offset: <private>, offset size: 16
default    08:40:38.404484 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer after offset: <private>
default    08:40:38.404485 -0500    kernel      input
default    08:40:38.404492 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x0,   arg0 0x2, arg1 0x113e7f000, arg2 0x8010 arg3 0xf6
default    08:40:38.404504 -0500    kernel    + IOAudioEngineUserClient::safeRegisterClientBuffer64 <private>
default    08:40:38.404513 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer before offset: <private>, offset size: 16
default    08:40:38.404516 -0500    kernel      !isOnline
default    08:40:38.404518 -0500    kernel    - IOAudioEngineUserClient::registerBuffer64 0x2 0x113e7f000 0x8010 0xf6 returns 0x0
default    08:40:38.404522 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x0,   arg0 0x3, arg1 0x113e88000, arg2 0x20010 arg3 0xf6
default    08:40:38.404532 -0500    kernel    + IOAudioEngineUserClient::registerBuffer64 0x3 0x113e88000 0x20010 0xf6
default    08:40:38.404559 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer before offset: <private>, offset size: 16
default    08:40:38.404559 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer after offset: <private>
default    08:40:38.404559 -0500    kernel      input
default    08:40:38.404561 -0500    kernel      assigning  clientBufPtr->mAudioClientBuffer32.mNextBuffer32 <private>
default    08:40:38.404561 -0500    kernel      !isOnline
default    08:40:38.404562 -0500    kernel    - IOAudioEngineUserClient::registerClientBuffer64() result 0x0
default    08:40:38.404563 -0500    kernel    - IOAudioEngineUserClient::safeRegisterClientBuffer64  returns 0x0
default    08:40:38.404563 -0500    kernel    - IOAudioEngineUserClient::registerBuffer64 0x3 0x113e88000 0x20010 0xf6 returns 0x0
default    08:40:38.404564 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.404567 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x0,   arg0 0x4, arg1 0x113ea9000, arg2 0x20010 arg3 0xf6
default    08:40:38.404568 -0500    kernel      scalarInputCount=0x4  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.404578 -0500    kernel    + IOAudioEngineUserClient::registerBuffer64 0x4 0x113ea9000 0x20010 0xf6
default    08:40:38.404603 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer before offset: <private>, offset size: 16
default    08:40:38.404604 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer after offset: <private>
default    08:40:38.404604 -0500    kernel      input
default    08:40:38.404605 -0500    kernel      assigning  clientBufPtr->mAudioClientBuffer32.mNextBuffer32 <private>
default    08:40:38.404622 -0500    kernel    + IOAudioEngineUserClient::registerBuffer64 0x5 0x113dd0000 0x20010 0xf6
default    08:40:38.404661 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer before offset: <private>, offset size: 16
default    08:40:38.404662 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer after offset: <private>
default    08:40:38.404663 -0500    kernel    - IOAudioEngineUserClient::registerClientBuffer64() result 0x0
default    08:40:38.404669 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x0,   arg0 0x6, arg1 0x113df1000, arg2 0x10010 arg3 0xf6
default    08:40:38.404680 -0500    kernel    + IOAudioEngineUserClient::registerBuffer64 0x6 0x113df1000 0x10010 0xf6
default    08:40:38.404711 -0500    kernel      assigning  clientBufPtr->mAudioClientBuffer32.mNextBuffer32 <private>
default    08:40:38.404758 -0500    kernel    + IOAudioEngineUserClient::safeRegisterClientBuffer64 <private>
default    08:40:38.404878 -0500    kernel    - IOAudioEngineUserClient::registerClientBuffer64() result 0x0
default    08:40:38.404938 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer before offset: <private>, offset size: 16
default    08:40:38.404948 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x0,   arg0 0x9, arg1 0x113e2c000, arg2 0x20010 arg3 0xf6
default    08:40:38.404949 -0500    kernel      scalarInputCount=0x4  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.404960 -0500    kernel    + IOAudioEngineUserClient::registerBuffer64 0x9 0x113e2c000 0x20010 0xf6
default    08:40:38.404961 -0500    kernel    + IOAudioEngineUserClient::safeRegisterClientBuffer64 <private>
default    08:40:38.404963 -0500    kernel    + IOAudioEngineUserClient[<private>]::registerClientBuffer64  (<private>[23], 0x113e2c000, 0x20010, 0xf6)
default    08:40:38.404990 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer before offset: <private>, offset size: 16
default    08:40:38.404990 -0500    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer after offset: <private>
default    08:40:38.404990 -0500    kernel      output
default    08:40:38.404991 -0500    kernel      assigning  clientBufPtr->mAudioClientBuffer32.mNextBuffer32 <private>
default    08:40:38.404992 -0500    kernel      !isOnline
default    08:40:38.404993 -0500    kernel    - IOAudioEngineUserClient::registerClientBuffer64() result 0x0
default    08:40:38.404993 -0500    kernel    - IOAudioEngineUserClient::safeRegisterClientBuffer64  returns 0x0
default    08:40:38.404994 -0500    kernel    - IOAudioEngineUserClient::registerBuffer64 0x9 0x113e2c000 0x20010 0xf6 returns 0x0
default    08:40:38.404996 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.405005 -0500    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x3,   arg0 0x0, arg1 0x0, arg2 0x0 arg3 0x0
default    08:40:38.405007 -0500    kernel      scalarInputCount=0x0  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    08:40:38.405017 -0500    kernel    + IOAudioEngineUserClient[<private>]::startClient() - 0
default    08:40:38.405018 -0500    kernel      audioEngine && !isInactive(). State = 1
default    08:40:38.405019 -0500    kernel      audioEngine->getState() != kIOAudioEnginePaused
default    08:40:38.405023 -0500    kernel    +- IOAudioEngineUserClient[<private>]::setOnline(1)
default    08:40:38.405022 -0500    kernel      !isOnline() setting online
default    08:40:38.405024 -0500    kernel    + IOAudioEngine[<private>]::startClient(<private>)
default    08:40:38.405025 -0500    kernel    + IOAudioEngine[<private>]::incrementActiveUserClients() - 0
default    08:40:38.405028 -0500    kernel    + IOAudioEngine[<private>]::startAudioEngine(state = 1)
default    08:40:38.405029 -0500    kernel    - IOAudioEngine[<private>]::startAudioEngine() returns 0x0
default    08:40:38.405030 -0500    kernel    - IOAudioEngine[<private>]::incrementActiveUserClients() - 1 returns 0
default    08:40:38.405031 -0500    kernel    - IOAudioEngine[<private>]::startClient(<private>) returns 0x0
default    08:40:38.405031 -0500    kernel      engine started
default    08:40:38.405032 -0500    kernel      bufferSet <private>
default    08:40:38.405033 -0500    kernel      output clientBuffer <private>
default    08:40:38.405033 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.405037 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.405037 -0500    kernel      output clientBuffer <private>
default    08:40:38.405037 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.405040 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.405041 -0500    kernel      output clientBuffer <private>
default    08:40:38.405041 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.405043 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.405047 -0500    kernel      output clientBuffer <private>
default    08:40:38.405048 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.405049 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.405050 -0500    kernel      output clientBuffer <private>
default    08:40:38.405051 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.405053 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.405053 -0500    kernel      input clientBuffer <private>
default    08:40:38.405054 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.405056 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.405057 -0500    kernel      input clientBuffer <private>
default    08:40:38.405058 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.405059 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.405059 -0500    kernel      input clientBuffer <private>
default    08:40:38.405061 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.405063 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.405064 -0500    kernel      input clientBuffer <private>
default    08:40:38.405064 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.405066 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.405066 -0500    kernel      input clientBuffer <private>
default    08:40:38.405067 -0500    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    08:40:38.405069 -0500    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    08:40:38.405069 -0500    kernel    - IOAudioEngineUserClient[<private>]::startClient() - 1 returns 0x0
default    08:40:38.405071 -0500    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    08:40:38.490683 -0500    kernel    + IOAudioEngineUserClient[<private>]::performWatchdogOutput(<private>, 30) - (2,dfc)
default    08:40:38.490706 -0500    kernel    - IOAudioEngineUserClient[<private>]::performWatchdogOutput(<private>, 30) - (2,efc)
default    08:40:38.517047 -0500    ProtectedCloudKeySyncing    attempting to subscribe to CK zone changes
default    08:40:38.517465 -0500    ProtectedCloudKeySyncing    [Operation 0x7fd092602060] Operation is flow controlled
default    08:40:38.517627 -0500    ProtectedCloudKeySyncing    Couldn't create database subscription; syncing is severely degraded: Error Domain=CKErrorDomain Code=7 UserInfo={NSUnderlyingError=0x7fd092001d70 {Error Domain=CKInternalErrorDomain Code=2008 UserInfo={CKRetryAfter=86928.1409059763, CKErrorDescription=<private>, NSLocalizedDescription=<private>}}, CKRetryAfter=86928.1409059763, CKErrorDescription=<private>, NSDebugDescription=<private>, NSLocalizedDescription=<private>}
default    08:40:38.517680 -0500    ProtectedCloudKeySyncing    Delaying 86928.6 seconds for CK operations
default    08:40:38.518226 -0500    cloudd    [Operation 0x7fc28916f090] Initialized with context 0x7fc28931e520. Background: 0, cellular: 1, QOS: 0x9
default    08:40:38.868675 -0500    trustd    could not enable test hierarchy: no UAT pinning preferences set
default    08:40:38.878407 -0500    locationd    {"msg":"kCLConnectionMessageWatchdog", "event":"activity", "this":"0x7fc25871c130", "registrationRequired":0, "registrationReceived":1}
default    08:40:39.085554 -0500    locationd    {"msg":"kCLConnectionMessageWatchdog", "event":"activity", "this":"0x7fc25840efb0", "registrationRequired":0, "registrationReceived":1}
default    08:40:39.636329 -0500    sharingd    Nearby stop scanning: scan request of type 16, blob: <>, mask <>, active: 0, duplicates: 0, screen on: No Scan, screen off: No Scan, rssi: -90, peers: (
) scan mode: 0
default    08:40:39.636410 -0500    sharingd    Nearby start scanning with data: scan request of type 16, blob: <>, mask <>, active: 0, duplicates: 0, screen on: 300, screen off: 300, rssi: -60, peers: (
    "7ED4ABD0-113C-4EB2-8DFE-BFA20D907BA1",
    "FFC7316C-4F82-4F0D-AE10-94F63E3F935C",
    "7B3479CE-E605-4AF3-B036-0FF11E4CE9BC"
) scan mode: 0
default    08:40:39.636552 -0500    wirelessproxd    Stop scanning for process sharingd (330) with scan request of type 16, blob: <>, mask <>, active: 0, duplicates: 0, screen on: No Scan, screen off: No Scan, rssi: -90, peers: (
) scan mode: 0
default    08:40:39.636607 -0500    wirelessproxd    Removing scan request scan request of type 16, blob: <>, mask <>, active: 0, duplicates: 0, screen on: No Scan, screen off: No Scan, rssi: -90, peers: (
) scan mode: 0 for client 6C2EBB6A-C845-4C8E-8FB5-44F6478E9B3A
default    08:40:39.636637 -0500    wirelessproxd    heySiriScanActive: NO
default    08:40:39.636686 -0500    wirelessproxd    Passively scanning for devices of types: 5 15 9 (Window: 30/Interval: 300)
default    08:40:39.636710 -0500    wirelessproxd    About to scan for type: 5 - rssi: -80 - payload: <00000000 00000000 00000000 00000000 00000000 0000> - mask: <00000000 00000000 00000000 00000000 00000000 0000> - peers: 0
default    08:40:39.636730 -0500    wirelessproxd    About to scan for type: 15 - rssi: -70 - payload: <00000000 00000000 00000000 00000000 00000000 0000> - mask: <00000000 00000000 00000000 00000000 00000000 0000> - peers: 0
default    08:40:39.636749 -0500    wirelessproxd    About to scan for type: 9 - rssi: -90 - payload: <00000000 00000000 00000000 00000000 00000000 0000> - mask: <00000000 00000000 00000000 00000000 00000000 0000> - peers: 0
default    08:40:39.636881 -0500    wirelessproxd    Scan options changed: YES
default    08:40:39.637245 -0500    wirelessproxd    Start scanning for process sharingd (330) with scan request of type 16, blob: <>, mask <>, active: 0, duplicates: 0, screen on: 300, screen off: 300, rssi: -60, peers: (
) scan mode: 0
default    08:40:39.637265 -0500    wirelessproxd    Adding scan request called
default    08:40:39.637305 -0500    wirelessproxd    Adding scan request scan request of type 16, blob: <00000000 00000000 00000000 00000000 00000000 0000>, mask <00000000 00000000 00000000 00000000 00000000 0000>, active: 0, duplicates: 0, screen on: 300, screen off: 300, rssi: -60, peers: (
default    08:40:39.637410 -0500    wirelessproxd    heySiriScanActive: NO
default    08:40:39.637453 -0500    wirelessproxd    Passively scanning for devices of types: 5 16 15 9 (Window: 30/Interval: 300)
default    08:40:39.637475 -0500    wirelessproxd    About to scan for type: 5 - rssi: -80 - payload: <00000000 00000000 00000000 00000000 00000000 0000> - mask: <00000000 00000000 00000000 00000000 00000000 0000> - peers: 0
default    08:40:39.637494 -0500    wirelessproxd    About to scan for type: 16 - rssi: -60 - payload: <00000000 00000000 00000000 00000000 00000000 0000> - mask: <00000000 00000000 00000000 00000000 00000000 0000> - peers: 3
default    08:40:39.637512 -0500    wirelessproxd    About to scan for type: 15 - rssi: -70 - payload: <00000000 00000000 00000000 00000000 00000000 0000> - mask: <00000000 00000000 00000000 00000000 00000000 0000> - peers: 0
default    08:40:39.637529 -0500    wirelessproxd    About to scan for type: 9 - rssi: -90 - payload: <00000000 00000000 00000000 00000000 00000000 0000> - mask: <00000000 00000000 00000000 00000000 00000000 0000> - peers: 0
default    08:40:39.637717 -0500    wirelessproxd    Scan options changed: YES
default    08:40:39.729113 -0500    wirelessproxd    WPDClient - Device Discovered: Client (6C2EBB6A-C845-4C8E-8FB5-44F6478E9B3A) Process (sharingd) Device (7ED4ABD0-113C-4EB2-8DFE-BFA20D907BA1) Type (16) Data (<4c001005 131873b5 05>)
default    08:40:39.729141 -0500    wirelessproxd    Telling process sharingd about discovered device 7ED4ABD0-113C-4EB2-8DFE-BFA20D907BA1 of type 16 with data <4c001005 131873b5 05>
default    08:40:39.729382 -0500    sharingd    Nearby didDiscoverType 1 UUID 7ED4ABD0-113C-4EB2-8DFE-BFA20D907BA1 info {
default    08:40:40.097103 -0500    dasd    Attempting to suspend based on triggers: (     "com.apple.duetactivityscheduler.deviceactivitypolicy.inusestatus",     "com.apple.duetactivityscheduler.restartpolicy.inusestatus" )
default    08:40:40.097690 -0500    dasd    501:com.apple.searchd.reindex:A8C367:[
    {name: DeviceActivityPolicy, policyWeight: 2.000, response: {Decision: Can Proceed, Score: 0.52}}
] sumScores:45.548420, denominator:46.510000, FinalDecision: Can Proceed FinalScore: 0.979325}
default    08:40:40.097817 -0500    dasd    Evaluating 125 activities based on triggers
default    08:40:40.098288 -0500    dasd    501:com.apple.suggestd.persist-stats:3B253C:[
] sumScores:35.548420, denominator:36.510000, FinalDecision: Can Proceed FinalScore: 0.973663}
default    08:40:40.098333 -0500    dasd    '501:com.apple.suggestd.persist-stats:3B253C' CurrentScore: 0.973663, ThresholdScore: 0.783198 DecisionToRun:1
default    08:40:40.098365 -0500    dasd    With <private> ...Tasks running in group [com.apple.dasd.default] are 2!
default    08:40:40.098896 -0500    dasd    0:com.apple.apsd.apprefresh:099563:[
    {name: PowerNapPolicy, policyWeight: 5.000, response: {Decision: Must Not Proceed, Score: 0.00, Rationale: [{(inADarkWake == 0 AND appRefresh == 1) AND wakeState == "0x1f"}]}}
], FinalDecision: Must Not Proceed}
default    08:40:40.098932 -0500    dasd    Running activities : <private>
default    08:40:40.099277 -0500    UserEventAgent    STARTING: <private>
default    08:40:40.149627 -0500    UserEventAgent    Initiating XPC Activity: com.apple.suggestd.persist-stats
default    08:40:40.149960 -0500    UserEventAgent    Running XPC Activity (PID 441): com.apple.suggestd.persist-stats
default    08:40:40.150389 -0500    UserEventAgent    Completed XPC Activity: com.apple.suggestd.persist-stats
default    08:40:40.150682 -0500    dasd    COMPLETED 501:com.apple.suggestd.persist-stats:3B253C at priority 5 <private>!
default    08:40:40.150772 -0500    dasd    NO LONGER RUNNING 501:com.apple.suggestd.persist-stats:3B253C ...Tasks running in group [com.apple.dasd.default] are 1!
default    08:40:40.151175 -0500    UserEventAgent    Rescheduling XPC Activity: com.apple.suggestd.persist-stats
default    08:40:40.151298 -0500    UserEventAgent    SUBMITTING: <private>
Re: @ RME Support: iMac Pro (T2 Chip) + Mojave + UFX = Audio glitches.
Looks like your Wifi is dropping in and out. What kind of Wifi router are you connected to?
Try disabling Wifi and test if the glitch still occurs?
yeah, I disabled the WIFI and same thing.  How did you found out about the WIFI?
7 (edited by Yannick Bisson 2019-11-05 17:54:32)
I wonder why the OS stops the audio core engine...
The thing is that I am ready to sell my UFX and go with UA instead ( getting out of RME's because of this bug) ...  but the line in the console maybe indicates that it is not UFX fault, and regardless of the sound card, I might get the same result.
That seems a reasonable thought! Anything you can maybe borough or try for free?
Oh Lucky me, I might get a RME UFX+ for rent to try out.  I'll post the result here.  Maybe tomorrow.
oh well, I speak too soon.  The RME UFX+ is out already. So...    anyone has a clue?  RME tech support perhaps??  MC??
11 (edited by cyrano 2019-11-06 02:10:24)
WPNearbyKeyRSSI = "-54";
Seems to indicate signal strength. Wifi and/or Bluetooth. But that's brand new, probably since Mojave?
And this:
) scan mode: 0
seems to have found three new? peers. Why it's causing Core audio to halt, is unclear. But I've seen sharingd cause glitches in audio since Mavericks. sharingd is part of Apple's background cloud messaging. Largely undocumented, as it is part of a private API in Macos. sharingd is file sharing. That's not as simple anymore. It's not only AFP and/or SMB, but it includes Bluetooth, for stuff like Handoff, Airplay and Airdrop, Homekit...
And then there's the notorious inter process communication...
Just before Core audio stops, there's "kCLConnectionMessageWatchdog", another one that's tied into the cloud. But again, largely undocumented. iOS seeping into Macos.
@cyrano,  thanks a lot!  That helps.   I am reinstalling *again* Mojave, and I will take care of Air Drop, Handoff ect....  I have an iPad and an iPhone, that might be the cause.
Again, thanks for the help, I appreciate!
13 (edited by hselters 2019-11-07 12:16:59)
You could try the Firewire connection using Thunderbolt 3 (to Thunderbolt 2 Adapter, and Thunderbolt 2 to Firewire 800 Adapter, Firewire 800 to 400 cable). Sounds wild but it works like a charm here on several RMEs. It is less buggy than USB with new Macs and should also work fine with all your iOS interaction.
Thanks for your recommendation!   I am still debugging for now as I think there is something not related to RME that causes the audio drop.  I installed a new sound card, and I get the same problem.  There is a process that stops the audio.  I will need to contact Apple when I got the time.
