Topic: Digiface Dante & OSC through LAN without TotalMix running?
Hi, just speccing out some Dante equipment for an install and considering the Digiface Dante for matrix processing and switching etc.
Couldn't find the answer as yet and cant test drive the software without an interface connected so tricky to establish fesability...
Wondering if it is possible to control the scenes/levels etc via OSC over the network port as opposed to having to have TotalMix running on a PC for OSC to work?
End goal would be running stand-alone plugged into the network rack with other PC's/apps on the network requesting channel changes via OSC or via apps like qLab etc which I currently do with the Behringer X32 range of consoles.
thanks.
