sysyphos wrote:I am also wondering about this topic and want to learn information from producers that is there any substantial 'hearable' difference between the old and new version.
I read that a new filter, whose name is low dispersion, will come to unit. Also, AK4493 will be used instead of AK4490 and a new remote will be introduced with the unit.
From what I've red, the new DAC chip allows this new SD LD filter (a very good compromise between latency, phase linearity and HF attenuation) and a best SNR (123 dB in XLR vs 120 dB for the first version).
The new version has also a little more headroom.
You have the differences between the units in the RME product page:
The updated ADI-2 DAC uses AKM's AK4493 in a special circuit variant developed by RME engineers that allows the chip to perform at its best. With noise levels of 123 dBA, distortion less than -120 dB, or THD+N of -117 dB, the device delivers outstanding measured values. Even the IEM output, with -118 dBu already the world's lowest noise headphone output, improves to a sensational -120 dBu. In addition, there is 4 dB of digital headroom, so that even high intersample peaks do not produce any audible distortion. Finally, the device now also offers a clear reserve in volume setting. +2.5 dB result in a still undistorted analog output signal.
And of course the improved remote.
It's good news of course, but nothing really "hearable"... Or very subtle... I've tried to compare by ear the filters, very hard to notice...
If you are about to purchase a new unit, of course buy the improved version. If you have the first version, I don't think the investment will really improve your listening experience.
