Topic: XLR max ref level is +13dbu
Hi, i'am use rme as preamplifier, connect on abrahamsen power amplifier via xlr, but the max ref level is only +13dbu.
Auto ref level is setting off.
Thank for Your answer (and sorry for my english)
RME User Forum → ADI-2 & 2/4 Pro series, ADI-2 DAC series → XLR max ref level is +13dbu
XLR has +6db already, so the XLR output levels are +1, +7, +13, +19dbu (DAC will display -5, +1, +7, +13 however)
Before last firmware update, i remember that the dac display 19dbu too... Is possibile?
See manual ch 30.2
Output level is switchable +19 dBu, +13 dBu, +7 dBu, +1 dBu @ 0 dBFS
yes, for example at 19.3 Line Out XLR:
Example: Ref Lev is set to +19 dBu......
it's as if the dac didn't recognize that I'm using xlr....
No. It never has shown something different than +13 dBu. And BTW, how could the DAC know that you use the XLR output? No detector switches in those...
