Topic: ADI-2 Pro digital through with eq + balanced headphones question
Is it possible to use ADI-2 Pro as dsp eq before digital monitors and as balanced headphones output simultaneously?
Like this:
Other interface aes out -> adi-2 aes in -> dsp eq -> aes out -> monitors aes in
Other interface adat out -> adi-2 adat in -> dsp eq -> balanced headphones out
As I read in manual section 17.3, both this chains should work in Ad/Da converter mode, with 3/4 headphones out, but manual is not clear about balanced headphones operation in this configuration. Will it work, or only phones 3/4 possible?
