> However, I personally am never satisfied no matter how much improvement I get.
Sounds to me as if you are missing a certain methodology which is required to come to good results.
Maybe you are not satisfied because something is still missing.
Perhaps the room acoustic is so bad, that the speaker do not sound like they should.
Or you didn't check enough other solutions which might sound better to your ears.
If I remember back it seemed, that you choosed already these speakers based on reviews and hearsay and you simply asked in the forum in the hope that people come to the same conclusion like the other people (that told you to buy these monitors).
May I ask: did you listen to these speakers or compare them with other speakers before you bought them ?
Then you wonder that you are never satisfied ..
I think with this methodology its not possible to get a system, that fully satisfies you.
Expensive cables are not able to change anything in that regards.
Same with a guitar, you need to compare different models and play them on your own to see whether the neck is good for your fingers and playing style, whether its sounds good, etc. You can not buy something organic like this only based on other ppls opineons. Even worse: everybody has completely hearing capabilities and tastes are different.
