There is something fishy going on with the M-Patch 2. According to the manual it doesn't work at all, because some graphics genius has drawn input and output XLRs where pins 2 and 3 are shorted. Also only a stereo pot is used, the whole unit works unbalanced internally.
Now pins 2 and 3 shorted maybe just an error but the unbalanced design made me check the web for photos of it inside. And indeed there is a 4 x pot as necessary to change volume in a balanced design. So the circuit diagram in the manual is total BS.
The unit can switch the input to an unbalanced source, using a simple stereo pot. How can the outputs then be balanced? It would require to short pins 3 of the XLR outputs to ground only in the Aux input mode to work at all, but there is nothing like this in the manual.
Finally the manual claims 'The JBL M-Patch 2 has an electronic circuitry inside as well as isolation transformers.'. I have no clue what they mean. The unit definitely does not have transformer-balanced inputs or outputs. The inner photos that I saw did not show any kind of transformer.
And as expected I did not find a single serious review that would clear all these questions...
