Topic: ADI Pro to replace Babyface
I currently use an original Babyface as a device to support multichannel playback with 4 channels out (2 via toslink and two analog) for a DSP room correction program called Acurate. I also use the mic preamp to record test signals. Total mix is used to route the correct signals from the PC to sound card. Can I use the ADI pro in a similar fashion using totalmix?
Thank you.
