1 (edited by N00b 2020-03-02 18:26:15)
Topic: Bit test: how to test 48 kHz flow?
Hi!
I've checked that my audio chain is bit perfect with the files provided by RME: bit perfect I am! (iTunes on my iMac, USB).
I want to check now my video set up: I often play video files on my Mac with VLC and send the audio+video through HDMI. My TV is connected to the DAC via Toslink and it works like a charm.
I just want to check if the audio is bit perfect (no resample by the player, OS or the TV) but no 48 kHz files... The 96 kHz bit test fails.
I remember that MC wrote it is possible to do so by editing the bit test files, does anyone can help me with this procedure?
Thanks!
2 (edited by Curt962 2020-03-03 00:57:22)
Re: Bit test: how to test 48 kHz flow?
N00b!!
I wish I had an answer for you, but I feel this matter would require an RME intervention.   A means of getting a Bit Test File to your TV, and a 48khz "Checksum" embedded in your ADI-2DAC's firmware would seem to be required, but let's have MC share his thoughts.    I KNOW your Gear is operating well...don't sweat it!
Best!
Curt
Cables:  Red, and White Ones.
Speakers:  Yes
Hi Curt!
Yes, I don't have any real issue, and my forehead is dry, don't worry!
It's just "intellectual curiosity". And if that need a firmware update, t's not worth it!
Use an editor and change the header to say 48 kHz. That's all. The files will be played a bit quicker, but that won't disturb the hardware detection, as it counts the samples in-between, and that is not changed by 'speed'.
OK MC, thanks a lot smile
Forgive me, I don't know English very well and I don't quite understand the bit test.
Does my file sound different, is there something wrong ??
The 192/24 file sounds different than the 192/32 and 44/16 files. Is it normal ??
I checked on several different players ??
I apologize for the translator.
The sound is not relevant.
Only thing that is relevant is the display message at the device "xx Bit Test passed".
Don't bother with the sound: just check the ADI screen: if you can see the label "Bit Test passed", it's OK. If you can't see this text, the Bit test failed.
See ADI-2 DAC manual on page 65 smile
Thank you !
10 (edited by N00b 2020-03-05 10:50:37)
Hi!
I've done this and it works, thanks! (My first time editing the header of an audio file, fun!)
If someone wants the 48 kHz file, I can send it smile
Hi!
Thanks. I did it too.
To do, open 96khz files with a Hex editor. And find & replace.
96khz 16 bit :
666D7420 10000000 01000200 00770100 00DC0500 04001000
==> 48khz 16 bit :
666D7420 10000000 01000200 80BB0000 00EE0200 04001000
96khz 24 bit :
666D7420 10000000 01000200 00770100 00CA0800 06001800
==> 48khz 16 bit :
666D7420 10000000 01000200 80BB0000 00650400 06001800
96khz 32 bit :
666D7420 10000000 01000200 00770100 00B80B00 08002000
==> 48khz 32 bit :
666D7420 10000000 01000200 80BB0000 00DC0500 08002000
that's it. enjoy.
