1 (edited by bassdaze 2020-03-25 19:45:25)
Topic: Mysterious Echo on RME FF802 - Mac OSX Catalina
When I playback any audio file using Cubase/Wavelab/Anytune, etc. sporadically I get these random echos - the audio seems to pause while echoing of the stereo output
analogs 1/2 for approx 1-2 seconds. It's very frustrating and usually means I have to switch to my other interface (Focusrite Clarett 8PreX) which seems to have no problem. I have no effects enabled in Totalmix and it doesn't happen in the same spot when I replay.
I have the latest driver/firmware installed in the FF802.
I have been having this for several months now adn I can't figure out why...
Can someone help???
Eddy
Mac Pro (late 2013) OSX 12.6.3 64 GB
RME Fireface 802 (USB)
FF802 driver v3.28 Firmware v19
Re: Mysterious Echo on RME FF802 - Mac OSX Catalina
have you tried all available USB ports?
3 (edited by bassdaze 2020-03-26 17:32:15)
No I haven't. It is directly connected to the port on my Mac Pro (not through a hub). I'll try that today and see what happens.
Thanks for the response!
Eddy
Well it has been doing it again with a different USB port - many times...
Any other ideas???
6 (edited by bassdaze 2020-04-06 22:53:02)
I'm wondering if my problem is related to https://forum.rme-audio.de/viewtopic.php?id=29899
I've quit Totalmix to see if that is the problem. For some reason, I thought Totalmix had to be running whenever you use the interface...
Anyway, some far it's working fine. It'll take some time to be sure.
