Topic: reconfiguring button assignments on the babyface (original)
Greetings. I am trying to set it up so I can toggle phantom power on input 1 simply by pressing the encoder or the "recall" button. It seems like this would be the menu to do it (see attached) but I'm not finding any instructions in the Babyface manual regarding the "ARC and Key Command Settings" menu under the Options pulldown. It's where I set the "select button to toggle between main and phones, so I thought this would be the place.
Thanks for any suggestions you might have.
