Topic: iem vs headphone jack
I don't get certain things of the iem plug.
The manual says it is used for high-quality In Ear Monitors but it works with "portable" headphones which do not require high power or voltage? but which power? which voltage?
So, it is by all means a typical 3,5mm jack with lower noise and power, right? I have two headphones around 33ohm, are they good to be plugged in there?
Or should I use an adapter and plug those to the 6,5mm one?
