Topic: Babyface crackle burst for 1.8 seconds every 125 seconds
I have a Babyface that I want to use in Standalone mode as a mic pre amp.
I have connected the SPDIF Output to the SPDIF Input with a high quality TOSLINK cable.
(I've also tested a different TOSLINK cable.)
The Babyface is running latest firmware, checked today.
It's powered over USB from a 1 amp USB power supply.
The crackle is happening on the LINE-OUTs of the breakout cable.
This happens even if I have nothing connected to the inputs.
(If I do connect microphones to the inputs then I can hear them at the output, so the device is working, but with crackles.)
I've put pictures and an audio recording and video here:
https://imgur.com/a/m5w4zWF
Does anyone know what might be causing this?
