1 (edited by rado 2020-05-19 14:35:03)
Topic: USB clock conversion to SPDIF out?
Is ADI-2 Pro FS capable of clock conversion from USB to SPDIF coax out? Let's say using 384kbps frequency via USB and outputing 192kHz to SPDIF?
Re: USB clock conversion to SPDIF out?
That would be downsampling - sorry, no.
3 (edited by rado 2020-05-19 16:18:26)
And upsampling is possible?
Problem is Tidal with stock Windows drivers cannot autoswitch frequency.
Audirvana can, but there are other problems...
My active speakers are connected via SPDIF (coax) and can handle up to 192/24, not more.
So, what would be the recommended setup for this case?
SPDIF out must be 192/24 or lower.
Currently I let Tidal and Windows WASAPI drivers resample everything to fixed 192/24, send it via USB to ADI-2 Pro FS BE, equalize it, control volume via RME, etc., and output it to speakers.
With Audirvana and/or Foobar and ASIO, my speakers will not play anything, if frequency is above 192.
Ideas? smile
Is resampling / downsampling (or setting maximum SPDIF OUT frequency) solvable via firmware update? smile
