Topic: Digiface Dante Multiclient problem
I know this is probably not so easy to solve but we're experiencing some problems with the "multiclient feature" of this card. We use it with 14 instances of the Softphone "Luci Studio" by Technica del Arte. Every instance is configured to use a different ASIO channel. When we start several instances of this application, randomly, one or two of these instances don't work. We get a UDP error and the only way to get them work again is to shutdown ALL the instances and restart them again. The manufacturer told us that if we have to shut down all the instances then this could be a problem with ASIO and suggested us to switch to WDM. We don't want that but we tried anyway to use WDM (WASAPI). This does not work at all, as we get another error (from the softphone): "Cannot Start Audio I/O, please check the sample rate or connections"
I don't know if this is a problem of our system, a softphone error or a RME Digiface Dante issue.
Does anybody have any idea?
Thank you very much in advance
Davide
