Topic: Audio Dropout with UFX II and Catalina
Faced an Audio Dropout and got this from Console log.
Did anybody face the same issue?
standard    11:44:40.991954+0200    coreaudiod     HALS_DefaultDeviceManager::CheckForChanges:            'dOut' --->>>
standard    11:44:40.991971+0200    coreaudiod     HALS_DefaultDeviceManager::UpdateDefaultDevice:        'dOut' --->>>
standard    11:44:40.991986+0200    coreaudiod     HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'dOut' --->>>
standard    11:44:40.992137+0200    coreaudiod     HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'dOut' | found preferred[1] 169: 'BuiltInSpeakerDevice'/'ispk'
standard    11:44:40.992137+0200    coreaudiod    *** ERROR: this process has called an NSArray-taking method, such as initWithArray:, and passed in an NSSet object.  This is being worked-around for now, but will soon cause you grief.
standard    11:44:40.992168+0200    coreaudiod     HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'dOut' <<<---
standard    11:44:40.992181+0200    coreaudiod     HALS_DefaultDeviceManager::UpdateDefaultDevice:        'dOut' <<<---
standard    11:44:40.992213+0200    coreaudiod    *** ERROR: this process has called an NSArray-taking method, such as initWithArray:, and passed in an NSSet object.  This is being worked-around for now, but will soon cause you grief.
standard    11:44:40.992228+0200    coreaudiod     HALS_DefaultDeviceManager::CheckForChanges:            'dOut' <<<---
standard    11:44:40.992328+0200    coreaudiod     -----------------------------------
standard    11:44:40.992341+0200    coreaudiod    *** ERROR: this process has called an NSArray-taking method, such as initWithArray:, and passed in an NSSet object.  This is being worked-around for now, but will soon cause you grief.
standard    11:44:40.992388+0200    coreaudiod     HALS_DefaultDeviceManager::CheckForChanges:            'sOut' --->>>
standard    11:44:40.992480+0200    coreaudiod    *** ERROR: this process has called an NSArray-taking method, such as initWithArray:, and passed in an NSSet object.  This is being worked-around for now, but will soon cause you grief.
standard    11:44:40.992501+0200    coreaudiod     HALS_DefaultDeviceManager::UpdateDefaultDevice:        'sOut' --->>>
standard    11:44:40.992588+0200    coreaudiod     HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'sOut' --->>>
standard    11:44:40.992748+0200    coreaudiod     HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'sOut' <<<---
standard    11:44:40.992815+0200    coreaudiod     HALS_DefaultDeviceManager::PickDefaultDevice:          'sOut' --->>>
standard    11:44:40.993019+0200    coreaudiod     Audio IO Overload inputs: '<private>' outputs: '<private>' cause: 'Unknown' prewarming: no recovering: no
standard    11:44:40.993294+0200    coreaudiod     Heap has 5 items
standard    11:44:40.993324+0200    coreaudiod       440: 'AppleGFXHDAEngineOutputDP:10001:0:{B44D-0000-00000000}'
standard    11:44:40.993355+0200    coreaudiod            Arrival Time:       (1000, 205000000000)
standard    11:44:40.993369+0200    coreaudiod            Transport:          'dprt'
standard    11:44:40.993382+0200    coreaudiod            Input Data Source:  ''
standard    11:44:40.993396+0200    coreaudiod            Output Data Source: ''
standard    11:44:40.993411+0200    coreaudiod            Input Kind:          None
standard    11:44:40.993423+0200    coreaudiod            Output Kind:         Display
standard    11:44:40.993490+0200    coreaudiod            Can Be Input:        no
standard    11:44:40.993542+0200    coreaudiod            Can Be Output:       yes
standard    11:44:40.993640+0200    coreaudiod            Can Be System:       yes
standard    11:44:40.993685+0200    coreaudiod       169: 'BuiltInSpeakerDevice'
standard    11:44:40.993726+0200    coreaudiod            Arrival Time:       (0, 0)
standard    11:44:40.993768+0200    coreaudiod            Transport:          'bltn'
standard    11:44:40.993797+0200    coreaudiod            Input Data Source:  ''
standard    11:44:40.993835+0200    coreaudiod            Output Data Source: 'ispk'
standard    11:44:40.993876+0200    coreaudiod            Input Kind:          Other
standard    11:44:40.993896+0200    coreaudiod            Output Kind:         Speaker
standard    11:44:40.994021+0200    coreaudiod            Can Be Input:        no
standard    11:44:40.994105+0200    coreaudiod            Can Be Output:       yes
standard    11:44:40.994187+0200    coreaudiod            Can Be System:       yes
standard    11:44:40.994210+0200    coreaudiod       178: 'de_RME_driver_USBAudioEngine:16B1445'
standard    11:44:40.994250+0200    coreaudiod            Arrival Time:       (1000, 10000000000)
standard    11:44:40.994326+0200    coreaudiod            Transport:          'usb '
standard    11:44:40.994411+0200    coreaudiod            Input Data Source:  ''
standard    11:44:40.994472+0200    coreaudiod            Output Data Source: ''
standard    11:44:40.994575+0200    coreaudiod            Input Kind:          Other
standard    11:44:40.994601+0200    coreaudiod            Output Kind:         Other
standard    11:44:40.994672+0200    coreaudiod            Can Be Input:        yes
standard    11:44:40.994759+0200    coreaudiod            Can Be Output:       yes
standard    11:44:40.994777+0200    coreaudiod            Can Be System:       yes
standard    11:44:40.994863+0200    coreaudiod       48: 'com.rogueamoeba.Loopback:C4C72531-B856-44AF-9DCC-90311B23E235'
standard    11:44:40.994888+0200    coreaudiod            Arrival Time:       (782, 255000000000)
standard    11:44:40.994950+0200    coreaudiod            Transport:          'virt'
standard    11:44:40.995006+0200    coreaudiod            Input Data Source:  ''
standard    11:44:40.995040+0200    coreaudiod            Output Data Source: ''
standard    11:44:40.995083+0200    coreaudiod            Input Kind:          Don't
standard    11:44:40.995110+0200    coreaudiod            Output Kind:         Don't
standard    11:44:40.995138+0200    coreaudiod            Can Be Input:        yes
standard    11:44:40.995207+0200    coreaudiod            Can Be Output:       yes
standard    11:44:40.995229+0200    coreaudiod            Can Be System:       yes
standard    11:44:40.995248+0200    coreaudiod       36: 'BlackHole_UID'
standard    11:44:40.995301+0200    coreaudiod            Arrival Time:       (874, 0)
standard    11:44:40.995322+0200    coreaudiod            Transport:          'virt'
standard    11:44:40.995337+0200    coreaudiod            Input Data Source:  ''
standard    11:44:40.995404+0200    coreaudiod            Output Data Source: ''
standard    11:44:40.995466+0200    coreaudiod            Input Kind:          Don't
standard    11:44:40.995553+0200    coreaudiod            Output Kind:         Don't
standard    11:44:40.995574+0200    coreaudiod            Can Be Input:        yes
standard    11:44:40.995616+0200    coreaudiod            Can Be Output:       yes
standard    11:44:40.995699+0200    coreaudiod            Can Be System:       yes
standard    11:44:40.995718+0200    coreaudiod     HALS_DefaultDeviceManager::PickDefaultDevice:          'sOut' | picking 440: 'AppleGFXHDAEngineOutputDP:10001:0:{B44D-0000-00000000}'/''
standard    11:44:40.995783+0200    coreaudiod     HALS_DefaultDeviceManager::PickDefaultDevice:          'sOut' <<<---
standard    11:44:40.995799+0200    coreaudiod     HALS_DefaultDeviceManager::UpdateDefaultDevice:        'sOut' <<<---
standard    11:44:40.995811+0200    coreaudiod     HALS_DefaultDeviceManager::CheckForChanges:            'sOut' <<<---
standard    11:44:40.995847+0200    coreaudiod     -----------------------------------
standard    11:44:40.995867+0200    coreaudiod     HALS_DefaultDeviceManager::CheckForChanges:            'shrd' --->>>
standard    11:44:40.995910+0200    coreaudiod     HALS_DefaultDeviceManager::UpdateDefaultDevice:        'shrd' --->>>
standard    11:44:40.996009+0200    coreaudiod     HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'shrd' --->>>
standard    11:44:40.996134+0200    coreaudiod     HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'shrd' | found preferred[1] 169: 'BuiltInSpeakerDevice'/'ispk'
standard    11:44:40.996154+0200    coreaudiod     HALS_DefaultDeviceManager::FindPreferredDefaultDevice: 'shrd' <<<---
standard    11:44:40.996169+0200    coreaudiod     HALS_DefaultDeviceManager::UpdateDefaultDevice:        'shrd' <<<---
standard    11:44:40.996236+0200    coreaudiod     HALS_DefaultDeviceManager::CheckForChanges:            'shrd' <<<---
standard    11:44:40.996275+0200    coreaudiod     -----------------------------------
standard    11:44:40.996335+0200    coreaudiod     HALS_DefaultDeviceManager::CheckForChanges:                 <<<---
standard    11:44:40.996357+0200    coreaudiod     ===================================
standard    11:44:41.203186+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.203216+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.203233+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.203250+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.203265+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.203296+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.203313+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.203327+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.203345+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.203363+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.365349+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.365384+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.365401+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.365415+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.365430+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.365443+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.365458+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.365473+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.365566+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.365586+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.464075+0200    coreaudiod    *** ERROR: this process has called an NSArray-taking method, such as initWithArray:, and passed in an NSSet object.  This is being worked-around for now, but will soon cause you grief.
standard    11:44:41.464153+0200    coreaudiod    *** ERROR: this process has called an NSArray-taking method, such as initWithArray:, and passed in an NSSet object.  This is being worked-around for now, but will soon cause you grief.
standard    11:44:41.506623+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.506650+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.506666+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.506683+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.506697+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.506714+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.506728+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.506747+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.506824+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.506936+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 464 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.516706+0200    coreaudiod    *** ERROR: this process has called an NSArray-taking method, such as initWithArray:, and passed in an NSSet object.  This is being worked-around for now, but will soon cause you grief.
standard    11:44:41.516805+0200    coreaudiod    *** ERROR: this process has called an NSArray-taking method, such as initWithArray:, and passed in an NSSet object.  This is being worked-around for now, but will soon cause you grief.
standard    11:44:41.816459+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.816494+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.816523+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.816550+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.816560+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.816644+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.816658+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.816669+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.816680+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
standard    11:44:41.816766+0200    coreaudiod     HALS_Device::_GetCombinedVolumeScalar: client 428 is not present and has a combined volume scalar is 1.000000
