1 (edited by StefanSNO 2020-06-08 18:11:02)
Topic: SOLVED - Can I connect a 600 Ohm impedance transformator to UFX-II?
I would like to know if I can connect an external unit (which has an input transformator with 600 Ohm impedance) to one of the analog balanced output of my RME Fireface UFX-II without harming the RME?
Is that impedance not much to too low for the RME?
BR Stef
RME Fireface UFX II, RME ARC USB, ADAM Audio, Big Sur, DP, VEPRO, Cubase 13 Pro.
Re: SOLVED - Can I connect a 600 Ohm impedance transformator to UFX-II?
No harming at all.
Thank you! Connection is made, all is fine :-).
BR Stef
