Topic: RME UCX and Windows 10 2004 may update
Hello
Total mix Fx doesn't work on the new version of windows 10!
It's Windows 10 2004 may update
A solution ?
RME User Forum → FireWire & USB series → RME UCX and Windows 10 2004 may update
Hello
A solution ?
Which device and driver version is this? What exactly "doesn't work"?
RME UCX connected wif usb
latest driver installed v1.168
Total mix doesn't start with windows, nothing in task bar
No driver icon also
But sound ok, vst ok
Problem only after update of windows 10
We are not testing on 2004 right now, too early to ruin our valuable test and development machines.
If the UCX is not in CC mode then you have to find out why Windows blocks the Settings dialog and TotalMix from starting. Find the files, try to start them manually, check Device Manager. Etc.
Or simply roll back to the former Windows version.
It's ok when i'm starting them manually.
Thanks.
Hope there'll be an update
Check your system startup options, maybe they are not active there. Not likely something that can be "updated" on the driver side.
Any news about Windows 10 2004 release ? Anyone updated, does it work fine or are there any problems ?
Meanwhile everyone updated, no new problems compared to 1909.
I installed 2004 on another SSD and while it works, i have frequent latency drop outs in Reaper when running at 128 samples. Same project is much more stabile at 1909, much less variance in RT longest block. Things like ALT+TAB cause spikes.
It's the same machine, same drivers, same RME UCX, same project, just two difference OS builds.
Any ideas ?
Many drivers have been updated to work better in 2004, so check around what is available for all the hardware in your computer.
