Topic: 'Linked' Dual Volume set to default
I need some help. I'd like to connect an active subwoofer to PH3/4 and the power amp to Main 1/2 (XLR), in order to set a high pass filter to output 1/2 and a low pass filter to output 3/4.
To simultaniously adjust the volume on both outputs ('linked dual volume') I have to press button 'VOL' two times after switching on the unit.
Is it possible to set 'linked dual volume' to default?
Or is there another way to connect subwoofer and power amp (passive speakers)? Connecting both, subwoofer (via RCA) and power amp (via XLR), to Main out 1/2 while applying a high pass filter to Main out 1/2, is that a good idea? Wouldn't the subwoofer suffer from high pass filter setting? By setting a high pass filter I mean rolling off the frequency at ~ 100Hz using EQ (See linked picture below, I hope it works).
