Topic: Volume control for digital/AES and analog outputs
Hello all,
I would like to use an ADI-2-Pro FS R as preamplifier, using the analog and digital outputs of the system in parallel. Is this possible?
In the setup, the main speakers should be driven by an analog power amp, and the subwoofers by a digital power amp that provides a digital AES & S/PDIF connection.
If relevant, this digital amp: https://www.hypex.nl/product/fusionamp-fa502/159
Does the volume control that can be used for the analog output optionally affect the level of the digital output as well? Is such a configuration supported?
Many thanks!
Martin
