Topic: Ufx+/m-32pro AD/DA/Dtox 16 i/o Feedback clipping on outboard gear I/O
Overload clipping on m-32 pro AD/DA send and returns for my outboard gear.
Checked cables, Madi connections/setup and total mix settings.
Not having this issue with the my Ufx+ hardware I/O running the same outboard gear and routing?
All my instrument inputs going into the m-32pro AD are working fine. Via TRS to D-Sub
My outboard gear in balanced connected Via my Dtox 16 i/O using Mogami D-sub.
Using Ableton as my Daw. Everything freshly updated.
Combing totalmix and Madi setup info for days. Must be something i'm missing.
Anyone out there with the same setup?
Information online for the m-32 pro series is minimal.
